PLEASE HELP ME
Old Feb 19, 2009 | 05:31 PM
mb197942's Avatar
PLEASE HELP ME
I HAVE SOME NICE DOOR PANELS FOR MY 72 CUTLASS COUPE BUT THEY ARE THE WRONG COLOR SOMEONE SUGGESTED I USE A 3M VINYL INTERIOR PAINT. WHATS YOUR THOUGHTS OR RECOMMENDATIONS
Old Feb 19, 2009 | 05:51 PM
44TEETWO's Avatar
I have used the SEM dye numerous times and with great success. Just make sure you get it from a GOOD paint shop and NOT IN SPRAY BOMBS! Get it in pints or quarts and use a good paint gun. If possible a gravity feed so you can use low air pressure. Also get the vinyl prep for the product IT IS WORTH IT! The finish is very nice. If all you are doing is the door panels a pint will do the trick. BEWARE sometimes the change parts lok better then the stock ones and the snowball starts a rollin'. (better get a quart).
Old Feb 19, 2009 | 06:09 PM
mb197942's Avatar
HOW MUCH DOES A QT USUALLY COST AND AS FAR AS PAINT STORES ARE YOU SAYING NOT TO USE OREILLEYS OR AUTOZONE THANKS FOR YOUR HELP
Old Feb 19, 2009 | 07:29 PM
Chumley's Avatar
I like SEM products also. Actually the spray cans yield good results if you can't do the spray gun thing as in my case. As stated, good surface prep is the key. I think I used two cans for the panels in the picture.
Old Feb 19, 2009 | 07:39 PM
mb197942's Avatar
those look great
Old Feb 19, 2009 | 08:18 PM
OLD SKL 69's Avatar
GM Enthusiast
I vote for the SEM products as well. I used both spray cans and out of the gun with excellent results.
Old Feb 20, 2009 | 07:17 AM
44TEETWO's Avatar
If I remember correctly the QT was about $65. Spray cans work if the person that made them knows what they are doing. I rather get the qt because I have little or no waste. The material is too expensive to waste and I also use it in my airbrush to do touch-up in the rest of the interior.
Old Feb 20, 2009 | 07:40 AM
ent72olds's Avatar
Registered Luser
DUPONT VINYL is an excellent product that you should be able to find at your autobody supply store...they also have a very helpful tech line. Don't forget to ask for tech sheets when purchasing!
Old Feb 20, 2009 | 08:09 AM
a64olz's Avatar
Vinyl dye
SEM, used it it on my dash pad and trim pads, used spray bombs, and prepped and then prepped again.
aquabird
Oct 2, 2013 10:34 PM
drtdobber
Feb 14, 2007 01:16 PM
Yllwbnna
Cars Wanted
Nov 13, 2006 09:50 AM
70ra455
May 26, 2006 12:30 AM
melsolds69
May 24, 2006 05:58 AM
