PLEASE HELP ME
I have used the SEM dye numerous times and with great success. Just make sure you get it from a GOOD paint shop and NOT IN SPRAY BOMBS! Get it in pints or quarts and use a good paint gun. If possible a gravity feed so you can use low air pressure. Also get the vinyl prep for the product IT IS WORTH IT! The finish is very nice. If all you are doing is the door panels a pint will do the trick. BEWARE sometimes the change parts lok better then the stock ones and the snowball starts a rollin'. (better get a quart).
If I remember correctly the QT was about $65. Spray cans work if the person that made them knows what they are doing. I rather get the qt because I have little or no waste. The material is too expensive to waste and I also use it in my airbrush to do touch-up in the rest of the interior.
