Please HELP Identify tail lights 70 Cutlass
Old Jan 20, 2019 | 03:46 PM
yorkman's Avatar
I have 3 of these tail lights that I picked up so many years ago that I don't remember what model they were from. I don't see any for sale anywhere. They are similar to Rally 350 except silver on the
sides with a painted silver stripe on the raised edge. Are they F85 or Cutlass S? Thanks, Bob
Old Jan 20, 2019 | 04:51 PM
RetroRanger's Avatar
72 Olds CS
I think the inner chrome rectangle denotes supremes. I'm no 70 expert tho
reread the op I've seen 70 supreme w stainless molding there, not painted ones, maybe someone added that after seeing a supreme?
still not a 70 expert!
Old Jan 20, 2019 | 05:04 PM
1970cs's Avatar
Lansing built
Yep 70 supreme would be correct. But I have heard that some may have made it on to other cutlass models.
Here is the tail end of mine, bad angle, you can see the silver inlay.
Pat
Old Jan 21, 2019 | 10:53 AM
Correct, the Supreme versions have stainless, not painted. I don't know which models used the painted ones.
Old Jan 28, 2019 | 07:57 AM
yorkman's Avatar
Cutlass S tail ligfhts
I have concluded that these tail lights are from 1970 Cutlass S models, including those with the W-31 option. It seems that these lenses are not reproduced and sometime back people just started using the 442 lenses without the inner silver stripe. Rally 350 models had the silver stripe but the sides were painted black.
Old Jan 28, 2019 | 02:22 PM
asx455's Avatar
Alan Reedy
There were 4 different types of rear lenses for 1970 only. The ones in the OP with the silver painted accent are for all F85, Cutlass, and Cutlass S models. The same painted accent was also used used on the Rallye 350 except with the edges painted black. The 442's had no accent on the center of the lens at all and was just all red. The Supreme's had an actual stainless insert applied onto the red lens. All 4 types are designated by different part numbers for their proper application.
L69
Feb 27, 2021 05:37 PM
Oldssupreme
Apr 3, 2015 08:36 PM
mbrae5
Oct 19, 2014 04:29 PM
oldsman72
May 26, 2013 06:32 PM
507OLDS
Oct 23, 2012 05:40 AM
