Pilot bearing
Old Aug 24, 2020 | 01:13 PM
mister-twister's Avatar
Pilot bearing
Anybody know, on a factory pilot bearing, do I pack the bearing with grease? Olds manual says clean the grease reservoir before installing the new. The bearing is open on one side, which faces the reservoir! Factory milled crank opening!
Old Aug 24, 2020 | 07:43 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
What year, what engine, what trans? What is a factory milled crank opening, not computing?
Sorry for 100Qs but we need all the basic info to help ya out.
Old Aug 24, 2020 | 08:09 PM
Of course, 1966 400, muncie. The crank is factory drilled, it's not a converta crank. I'm using a national bearing, exposed raceway on one side, sealed opposite.
Old Aug 25, 2020 | 05:27 AM
Oldsmaniac's Avatar
I always put some grease on the open side of the bearing and put that end in 1st with the sealed side out towards the trans.
Old Aug 25, 2020 | 06:01 AM
Sugar Bear's Avatar
Cleaning out the old grease makes sense because grease in the reservoir could prevent the new bearing from fully seating or get pushed into the new bearing and grease.
After cleaning it out I'd install it the way Oldsmaniac said.
Good luck!!!
Old Aug 25, 2020 | 06:59 AM
My442's Avatar
Originally Posted by oldsmaniac
i always put some grease on the open side of the bearing and put that end in 1st with the sealed side out towards the trans.
this^
Old Aug 25, 2020 | 08:09 AM
My next dilemma, should I use a light body grease? I'm assuming the grease would flow into the bearing during acceleration to keep it from starving for longevity, hence the reservoir.
Old Aug 25, 2020 | 11:08 AM
Oldsmaniac's Avatar
I use any general purpose grease, not lithium though...
Old Aug 25, 2020 | 06:12 PM
This will work fine. I think it's a good design from olds too. I am using castral, GP...Thanks to all!
Bobby455
Oct 27, 2018 01:11 PM
olds70supreme
Sep 3, 2018 04:53 PM
67Rocket
Jul 3, 2016 12:18 PM
Bfg
Mar 16, 2013 07:00 AM
SRV8
Oct 2, 2012 01:47 PM
