PCV grommet slides on valve cover
Old Jan 2, 2022 | 01:07 PM
Donaldbabineau's Avatar
I replaced the PCV on my 71 cutlass supreme and noticed the grommet was able to slide/rotate a little on the valve cover. The PCV fits snug in the grommet. I was able to rotate the grommet till it seemed to fit snug on the valve cover, but I doubt it is sealed. Considering the PCV is connected to the carb, will a grommet that is not completely sealed create a vacuum leak? If so, what can be done short of replacing the grommet. Do I need to remove the valve cover to replace it?
Old Jan 2, 2022 | 01:27 PM
Use some black weatherstip adhesive in the groove that meets the valve cover. Once dry it will not move or leak.
Old Jan 2, 2022 | 01:52 PM
should the grommet be hard plastic? Mine is and may be so from age. My concern is I may not be able to remove the grommet without breaking it to apply the adhesive. To remove the grommet, do I pry it off with a flat screwdriver? If I can't remove the grommet, I suppose I could flatten a thin bead around the crack, but I haven't worked with that material before.
Old Jan 2, 2022 | 01:57 PM
The crankcase is vented to atmosphere anyway. This isn't going to cause a vacuum leak.
Old Jan 2, 2022 | 02:04 PM
okay Joe, I thought what you are saying might be the case. But for my understanding, how does an unsealed fitting connected to a very large port in the carburator not cause a vacuum leak?
Old Jan 2, 2022 | 02:11 PM
Because the PCV valve has a orifice in it that restricts flow, and the carb is calibrated to account for that flow. If you pull the PCV valve completely out of the grommet, the engine still runs with no changes.
Old Jan 2, 2022 | 02:13 PM
Good to know. Glad I don't have to mess with it.
Old Jan 2, 2022 | 04:00 PM
69HO43's Avatar
You may not have to, at least not from a vacuum leak standpoint. However, if the material gets too loose in the hole or starts to deteriorate further, you could get an oil seepage where the grommet goes into the cover. Not saying you will, it's just something that might show up down the road. Then you can just replace it. Taking it out to seal it with sealant is kind of a no-win situation since you'd be taking it out anyway. Why not pop a new one in if you go that far?
Usually, if they're still pliable, you can squeeze the pee out of them, or a plastic trim removal tool to get a corner lifted to be able to leverage it out of the hole. Be careful not to go crazy and tear it up or you could get little rubber bits in the head. It may or may not be an issue in the big picture, but I don't like foreign particles in the oil system. I probably wouldn't do it now if it's not leaking oil.
Old Jan 2, 2022 | 04:05 PM
yeah it's probably taken 51 years to get to the point it's at. No oil is leaking.
Almond900
Feb 26, 2016 02:56 AM
coldfire
Jul 14, 2013 09:42 AM
mcutlass1969
Nov 29, 2011 05:40 AM
67Olds442X2
May 22, 2011 05:28 PM
defiant1
Mar 23, 2011 07:50 PM
