Passing gear kick down cable 70-72
Old Aug 1, 2012 | 07:05 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Can sombody give me the run down if my 400 is electric and has that switch by the gas petal?? my 70 has it what about the 72?
Old Aug 2, 2012 | 05:49 AM
oldspackrat's Avatar
The 350 transmissions had a kickdown cable attached to the gas pedal inside the car. If you look at the top of your pedal, you should see two cables, one throttle, one kickdown. If you have a 400, you should see a small metal bracket with a switch with a 2 wire connector attached to it & only one cable. I have several extra switches & maybe an extra bracket if you need them.
Thanks.
Scott
c. 317-727-7041
Old Aug 2, 2012 | 09:08 AM
Olds Specialist LOL
Yes I could use the switch
But my car used to be a stick will it still be there?
Old Aug 2, 2012 | 01:15 PM
If it was a stick neither the switch nor the bracket will be there. I will check to see if I have both.
1yesfan
Aug 4, 2015 06:40 PM
Jetaway 253
Jun 8, 2013 05:11 AM
bulldogs#10
Feb 29, 2012 06:17 AM
pophop
Nov 5, 2009 12:26 PM
jackmanola
Jul 6, 2008 03:59 PM
