Passing gear kick down cable 70-72
The 350 transmissions had a kickdown cable attached to the gas pedal inside the car. If you look at the top of your pedal, you should see two cables, one throttle, one kickdown. If you have a 400, you should see a small metal bracket with a switch with a 2 wire connector attached to it & only one cable. I have several extra switches & maybe an extra bracket if you need them.
Thanks.
Scott
c. 317-727-7041
Thanks.
Scott
c. 317-727-7041
