Parts we need reproduced
Old Apr 11, 2015 | 08:17 AM
  #41
Originally Posted by wr1970
Why not make a place where all bad fitting repo parts can be listed and who sells with a buyer beware disclaimer? That way everyone would know!
Here ya go:
https://classicoldsmobile.com/forums...rk-thread.html
Old Apr 11, 2015 | 08:55 AM
  #42
Charlie Jones's Avatar
Phantom Phixer
63-64 Battery trays
Almost every 63 or 64 full size car I have seen needs a battery tray.
It looks like a fairly simple part to reproduce.
Old Apr 11, 2015 | 09:10 AM
  #43
bob p's Avatar
Rocketeer
Originally Posted by dynamic63
I vote any sheet metal for 63-4 fullsize quarter bottoms, rocker panels, floor pieces, even just the bodymount sections.
I vote for just about any part on a pre-1964 car.
Old Oct 9, 2015 | 11:47 PM
  #44
Hoffman2099's Avatar
70-72 Cutlass/442 full quarter panels, 70-72 Cutlass/442 lower fender patches and braces, 70-72 Cutlass/442 tail panel and the lip that holds the weatherstripping in because that always rots out, and core support patch.
Old Oct 10, 2015 | 03:20 AM
  #45
Levellord's Avatar
I add:
- 1972 CS seat belt retractor cover with the small flap (5210 lh/rh)
- lower steering column cover
Didnt manage to find it.
Old Oct 10, 2015 | 03:51 AM
  #46
wr1970's Avatar
Originally Posted by Levellord
I add:
I think opgi sells these and year one.
Old Oct 10, 2015 | 04:57 AM
  #47
Levellord's Avatar
Unfortunately not. They all sell the rcf300/400 and robbins cover, none of them matches to a 72er. And I mean the lower plastic column cover which is screwed directly to the dash with two screws, not the one in the carpet :-(
Old Oct 10, 2015 | 07:49 AM
  #48
ezman604's Avatar
Ignition switch connector '68 4-4-2.
Have a friend that is going to try 3D printing one.
Old Jul 14, 2016 | 08:47 PM
  #49
anthonyP's Avatar
While looking at the Buick Performance Club website, one of the pages noted reproduction lower fender braces. It seems the club president asked Sherman Auto Parts to make the replacement lower fender braces for their Buick fender patch panels.
Maybe some of the members who do body work can take a look at them to determine if these reproduction lower fender braces can be used with an Oldsmobile patch panel or fender.
Old Jul 15, 2016 | 08:56 AM
  #50
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
68 trunk lip molding. The wings are being made(both). These things are like hens teeth NOS or in good shape with all studs intact.
68 power antenna with switch and harness.
68 map light.
Old Jul 15, 2016 | 11:29 AM
  #51
biggus's Avatar
68 442-S hood.
Old Nov 24, 2016 | 07:55 PM
  #52
Funkwagon455's Avatar
Originally Posted by Funkwagon455
The molded rubber rear bumper/step closeout on 68-72 wagons...
Hallelujah A body wagon lovers, the day has arrived!
http://www.steelerubber.com/rear-bum...set-70-3637-87
Old Nov 25, 2016 | 06:35 AM
  #53
RetroRanger's Avatar
72 Olds CS
This isn't Sherman but it looks similar to the lower fender brace and a reasonable price as well!!!
First funkwagons parts now this it really has been a day to give thanks
Old Nov 25, 2016 | 09:10 AM
  #54
w-30dreamin's Avatar
71 & 72,now I want a 68
Here are some small parts the industry can use reproduced correctly. I have found some they sell but are unusable,totally wrong size.
Ever try to find these NOS? Very difficult to find.
Throttle cable bushing,grommet and washer.
Old Nov 25, 2016 | 10:21 AM
  #55
Those parts are readily available, called throttle linkage bushings.
Old Nov 25, 2016 | 01:11 PM
  #56
When I needed these parts all I could find from the repop places were to wide and do not fit.
Here's a pic of part of an original and what you receive from the aftermarket.
Old Nov 25, 2016 | 01:33 PM
  #57
Have you tried Holley for the part?
Old Nov 25, 2016 | 05:55 PM
  #58
No I did not try Holley.
After plenty of searching I finally found a couple nos sets which are in the first pic.
Would Holley have parts for a factory quadrajet throttle linkage assembly?
Old Nov 26, 2016 | 04:51 AM
  #59
Inline's Avatar
73-77 Cutlass interior plastics def. need reproduced.
Old Nov 26, 2016 | 07:04 PM
  #60
truckman5000's Avatar
W30
Or a lower 4 inch patch panel for the rear quarters. I see people all the time replace the entire patch panel for the lower 2 or 3 inches.
I just got one, abc? out of Connecticut it was alittle less than the whole quarter, but less ship. and came very quick
Old Nov 27, 2016 | 06:00 AM
  #61
Those same bushings are used on a variety of makes. The hole that they fit in is the same on a multitude of carbs.
Old Nov 29, 2016 | 07:37 AM
  #62
AJFink's Avatar
How about the package tray assembly that's under the rear deck plate For 70 - 72.
stlbluesbrother
Mar 31, 2022 09:58 PM
Oldsmaniac
Dec 17, 2014 10:54 AM
kwhitehead
May 17, 2014 07:51 AM
Octania
Sep 24, 2013 05:42 PM
mmurphy77
Hurst/Olds
Jan 22, 2013 05:52 AM
