OW vs OG TH400 trans
Old Jul 19, 2010 | 07:39 AM
VikingBlue's Avatar
Aside from the tag....is there any difference between a 1971 W30 trans and a 1971 442 trans ?
Or are all TH400s in a given year (or across years) the same ?
Old Jul 19, 2010 | 09:44 AM
Well, GM didn't typically give identical parts different designations...
Internal differences include the number of clutch plates in a given drum, the stall speed of the converter, the weights on the governor, the configuration of the valve body and spacer plate, the stiffness of various springs used in the spool valves and accumulators, etc.
Old Jul 19, 2010 | 09:48 AM
VikingBlue's Avatar
thanks...at a minumum I figure they did just put different tags on the same transmission in different makes...e.g. there must have been a Buick trans identical to an Olds trans except for the tag.
Old Jul 19, 2010 | 03:17 PM
BlackGold's Avatar
If Hydramatic did put different tags on the same trans for different GM Divisions, it would've been pure coincidence. The Divisions really were quite independent back then. While all GM A-bodies shared many chassis components, each Division was responsible for fine-tuning their combinations: spring rates and heights, shocks, body mounts, and yes, transmission shift points and firmness.
TRW
Jan 21, 2011 05:38 AM
ls442
Nov 11, 2010 10:45 PM
455Gbody
Aug 4, 2009 07:19 PM
BigBertha442
Mar 1, 2008 08:16 AM
cutlass72
Jan 2, 2004 05:26 PM
