Output shaft diameter
Old Sep 25, 2017 | 06:43 PM
Vehicle - 1972 Cutlass
Transmission - TH350
Original gears (SA - 2.73)
Gears and carrier have been changed to 3.42:1 and limited slip.
Tire size 225/70/14
The TH400 could be ordered with the 3.42 gears, but it wasn't available on the 350 cars.
Question 1: Are the output shafts on the TH350 and TH400 the same diameter?
I want to put in the proper drive and driven gear that will correct the speedometer and odometer readings. I have no interest in just running GPS for speed.
Question 2: Will the sleeve for the TH350 work with the driven gear for a TH400? There's no information about this in the 72 CSM - I looked at the charts and all they provide is the gear ratio and driven/drive gear
My guess is the output shafts are the same diameter, but I'd like confirmation before ordering a new drive gear, and/or sleeve.
Old Sep 25, 2017 | 06:55 PM
toymobile's Avatar
Out put shaft NOT EVEN CLOSE, must be for TH350.
Johnny
Old Sep 25, 2017 | 07:49 PM
Did you check other years? The W-31 cars with automatic trans (TH350) had 3.42 gears as the G92 option.
Old Sep 26, 2017 | 05:53 AM
Kenneth, no I didn't. That's a great suggestion. I don't have a 1970 CSM though.
Aceshigh
Dec 9, 2013 09:56 AM
Frogge467
Apr 8, 2012 09:18 AM
Frogge467
Mar 24, 2012 11:09 PM
MLK-442
Mar 21, 2012 11:08 AM
drewt
Mar 16, 2010 07:18 PM
