original hole size?
Old Mar 11, 2016 | 01:25 PM
brandon reynolds's Avatar
original hole size?
Does anyone know what the original size of this hole should be on a 68-72 442 clutch z bar? Thanks brandon
Old Mar 11, 2016 | 07:23 PM
Anyone?
Old Mar 11, 2016 | 07:52 PM
steverw's Avatar
I dont know but i think there is a bushing that goes in that hole which then would have a smaller, probably 3/8 hole in it.
Old Mar 11, 2016 | 08:00 PM
BackInTheGame's Avatar
Size
Yes, there is a bushing - on both ends. I had to replace the bushings on both ends of my bellcrank. Fusick and others sell them, including McMaster Carr - much better price at MC, but you need the dimensions. I'll try and find the numbers that I measured when I replaced mine.
Old Mar 12, 2016 | 03:13 AM
The assembly manual doesnt show a bushing in there and i can find them in fusick or inline tube catalog. If you have any info on these it would be appreciated. Thanks brandon
Old Mar 12, 2016 | 06:17 AM
allyolds68's Avatar
FWIW I don't know if the hole sizes are the same but 68-69 Z-bars are not the same as 70-72's
Old Mar 12, 2016 | 06:36 AM
Paladin31's Avatar
70-72 GM part# 406172 available at several places, Carid for one $3.18
http://www.carid.com/oer/clutch-peda...pn-406172.html
Don't have the spec's on the bushing handy
Brett
Old Mar 12, 2016 | 11:40 AM
I thought that bushing was for the clutch pedal as the assembly manual show. Is it the same bushing for the z bar too?
Old Mar 12, 2016 | 12:44 PM
Paladin31's Avatar
Brandon the parts book states it fits both the rod -arm, rod-lever, and shaft. appears 3 pieces per assembly
Brett
Old Mar 17, 2016 | 02:15 PM
The rod from the clutch pedal to the Z-bar is a different diameter than the rod from the Z-bar to the fork so they couldn't use the same bushing so back to my original question does anybody know the whole size on the Z-bar that goes to the clutch fork pushrod or have a picture of one showing a factory bushing in there?
Wood
Nov 15, 2015 03:56 PM
csouth
Apr 13, 2013 01:35 PM
RAMBOW
Aug 18, 2012 12:00 PM
Flye
Brakes/Hydraulic Systems
Jun 24, 2012 06:38 PM
cheven
Wheels and Tires
Jun 14, 2012 10:34 AM
