Original GM Frigidaire AC Compressor
Can this compressor be run with R-134? Says R-12. I know the valve ?? (can't think of the name) would need to be recalibrated for R-134. Would like to keep it if its not broke.
This compressor can definitely run on R-134, it has been doing so in my Starfire for the last 4 years and I'm sure many other cars as well. Others will weigh in here but I think the minimum you have to change is the charge valves and oil plus flush and evacuate the system.
Life just has too many questions doesn't it?
I do so enjoy the CSM.
Especially on page 1A-15 in regards to the a/c compressor shaft seal replacement when the 1st step is
"1. Discharge the system by releasing the refrigerant into the atmosphere."
Somehow I think that would be frowned upon nowadays (Not that most of us of a certain age haven't done that before).
If the system is all disassembled you should replace all rubber lines and O-rings. Check all the major components for leaks and consider rebuilding the compressor. With an open system no telling what is inside...
I disassembled the system (Just unhooking everything). At one of the fittings Low pressure side the aluminum line to fitting was cracked and thus all refrigerant got away. There was some oil in the lines very little. I have not taken the compressor apart/taking the high and low pressure lines off yet. Would like to leave well enough alone, (not broke don't fix) but if rebuilding the compressor is easy enough to do I'll do it. I was going to replace the high and low pressure lines, drier, and have the POA adjusted to accept R-134, Clean the evaporator.
This is going to be a part time driver/cruise night car and I just want to be cool on those hot summer nights. Yes I know R-12 is colder, But $$$$$ to keep up with.
Nailhead 88
June 22nd, 2009 01:59 PM
