Opinions on fiberglass hood
Old Jan 13, 2011 | 12:46 PM
455man's Avatar
http://www.rocketracingperformance.c...ok9rg6gro3sm32
71-72 442 REPRODUCTION RAM AIR FIBERGLASS PIN ON HOOD W/RAISED SCOOPS W/ AIR BOX. THESE ARE AN ADDITIONAL 2 INCHES ABOVE STOCK.
Bigger scoops. I'm sure the guys that do original restorations are not interested in this but what about the clones?
Old Jan 13, 2011 | 01:40 PM
alek72us's Avatar
Olds Dreamer
Personaly I dont think i would like it but i would have to see one all painted and on the car.
Old Jan 13, 2011 | 01:49 PM
455man's Avatar
http://www.realoldspower.com/phpBB2/...ic.php?t=68745
Hope it's ok to post links to other forums...
Old Jan 13, 2011 | 01:53 PM
alek72us's Avatar
Olds Dreamer
I dont like it, but that is my opinion. the black one dont look to bad though.
Old Jan 18, 2011 | 07:10 AM
455man's Avatar
Anyone else?
Old Jan 18, 2011 | 07:34 AM
gearheads78's Avatar
car guy
You know its just a pin on race car type hood right? You can't open by hinges. you have to lift it off and set it somewhere it won't blow away any time you want to do something as simple as checking the oil.
Old Jan 18, 2011 | 07:39 AM
455man's Avatar
It looks like they have the bold on hoods also. That would be a pain to lift off the hood just to change the oil.
Old Jan 18, 2011 | 08:50 AM
Looks like a caricature to me, but that's just my opinion. The bigger question is why? If you think you'll be getting more clearance for a taller intake, you won't. The part of the hood between the scoops (and directly over the carb) is at the same height as on any other O.A.I. hood.
Old Jan 18, 2011 | 10:26 AM
380 Racer's Avatar
Actually it isn't bad taking the hood off and putting back on (mine is lift-off also).
The hood looks much better since Bob got the black painted on top of the scoops.
Bob did tell me he gained clearance between the scoops.
Old Jan 18, 2011 | 10:44 AM
507OLDS's Avatar
I think they look more like a cartoon.You will gain some hood clearance with those large-scooped hoods,which are made by Glasstek.
There is another hood being made by Schononeck Composites,in Minnesota,which has scoops 1" taller than stock,and the center is flush with the scoops.These hoods have the same amount of hood clearance as the large scoop hoods from Glasstek.However,the Schononeck hoods are only available for 70 right now.He needs a 71-72 OAI hood to take a pattern from.The nicer the better.He will not damage it,or even scratch the paint.I have talked with Danny,and I might send one of my hoods out there,if it comes to that.
Glasstek also offers another hood with stock height scoops,and the center raised flush with the tops of the scoops.
Basicly,there are currently 3 options for custom OAI hoods,but Robert,at Glasstek,can make other custom hoods as well.
Olds luvr
Nov 9, 2013 09:19 AM
RetroRanger
Sep 22, 2012 06:12 PM
theoldsrocket
Mar 24, 2011 01:03 PM
Ducman
Dec 5, 2007 06:56 AM
