Olds in GMC
Old Jun 23, 2011 | 08:56 PM
64Rocket's Avatar
Olds in GMC
I like it, this should be done more often.
http://sfbay.craigslist.org/sby/cto/2457324082.html
Old Jun 23, 2011 | 09:03 PM
my72vert's Avatar
Its gotta be worth more than 7 dollars.
Old Jun 23, 2011 | 10:48 PM
64Rocket's Avatar
It is a ploy to get people to look at the ad.
Gene
Old Jun 23, 2011 | 11:09 PM
jo75olds's Avatar
I would buy that for $7, not $8 though, thats out of my price range
Old Jun 24, 2011 | 06:33 AM
Yeah, this was pretty common in the 1980s when Chevy/GMC trucks used the Olds diesel. The easiest fix once the diesel died was to bolt in an Olds gas motor. Of course, in the early 1980s cheap, running 455s were still easy to find.
Old Jun 24, 2011 | 06:56 AM
Willidog's Avatar
Official Tire Kicker
Gene
It's also used to keep the scammers away, when you have a normal price on Craigs List you start getting the E-MAILs saying that the person E-MAILing you is an "agent" for some other person and they want to send you a check for more than what it is worth and you can keep the difference if you just cash the check. At least that's what started happening to me when I first started posting on CL.
Old Jun 24, 2011 | 07:12 AM
64Todd's Avatar
1972 Chevy
My uncle dropped a 455 in his 72 C20 pick up. He has been running the 455 since 1978.
Old Jun 24, 2011 | 09:57 AM
starfire's Avatar
What engines did GMC use prior to the 80's/corporate engine era?
Old Jun 24, 2011 | 10:22 AM
GMC has used Chevy engines since the late 1950s. The Olds diesel was an anomaly because it was the only diesel GM had at the time and was used by every division. In the 1940s and 50s, GMC had their own inline six cylinder engines, and even used some Pontiac and Olds V8s in the late 1950s.
Old Jun 24, 2011 | 11:15 AM
f-85's Avatar
GMC also had a 305 V6 looked like a W motor That was the smallest V6 they made in that design. They even made a V12 The 305 Was an option for the early 60-66 GMC 1/2-1 ton trucks. My buddy has one in his 65 short step, we are about to pullit and swap in a BBO with a 400 trans.
Old Jun 24, 2011 | 11:24 AM
Good point, I completely forgot about the V6 family, unique to GMC in the 1960s. These were 60 degree motors, and they made small and large V6s, a V8 (yes, with 60 degrees between the cylinder banks) and the V12 (which was only used in the heavy duty trucks). The 702 cu in V12 was actually two of the 351 cu in V6 motors in a common block. The V12 used four of the V6 heads and valve covers, with two separate 2bbl carbs feeding each "V6" motor.
And as a precursor to the ill-fated Olds diesel, there was a diesel conversion to this V6 family. Called the Toro-Flow, or something like that, it also didn't last very long.
Old Jun 24, 2011 | 10:08 PM
Redog's Avatar
I like that truck
Old Jun 28, 2011 | 02:45 PM
nonhog's Avatar
Registered car nut
I'm thinking about getting a Chevy or GMC truck for a place to install a BBO (someday-dream stage now) I'd do some minor grill/headlight/tailgate mods to make it an Olds pu.
If your up for a laugh here is a couple of "paint" mods I did on a Google image.
I included the before pic in case someone knows how to photoshop it better.
Old Jun 28, 2011 | 07:44 PM
firefrost gold's Avatar
maybe we can get fizzy55 to post his bow tie w-30 .
Old Jun 29, 2011 | 06:42 AM
Originally Posted by nonhog
...I'd do some minor grill/headlight/tailgate mods to make it an Olds pu.
I'm guessing you've never owned a 1969 or 70 with the "head banger" hood tooth.
Old Jun 29, 2011 | 09:11 AM
nonhog's Avatar
Registered car nut
"head banger" you must be refering to a 69 or 70 Olds? Yes I had a 70, at 1st I couldn't figure out "head banger" on a 70 Chevy pu then the coffee kicked in. Had a 70 of each.
I'd probably leave the "tooth" in the grill. Heck who am I kidding. My list of projects is so long now, this one will likely stay in the day dream stage.
Still a fun idea (I think)
Intragration
Feb 6, 2013 05:02 AM
VikingBlue
Jan 12, 2013 07:15 AM
Glennerd
Dec 12, 2011 07:24 PM
GMCEd
Nov 10, 2011 07:12 AM
Glennerd
Oct 24, 2011 05:40 PM
