olds 330 fuel difference in octane
Old August 10th, 2011, 11:54 PM
CutlassLegend's Avatar
330 LC 2 barrel. Has been running from the original owner for eyars with 87-89. Do you think if I fill it after she gets close to E with 93-94 it will make a big difference, what could I expect. Thanks for you insight.
CutlassLegend is offline
Old August 11th, 2011, 03:54 AM
a64olz's Avatar
It will not make a big difference, and you can expect to spend more money on fuel. If properly tuned, 8.5 - 9.0 compression ratio cars will run on almost anything.
a64olz is offline
Old August 11th, 2011, 04:05 AM
Since it's a low compression motor, it should run on regular if properly set up and tuned.
Maybe not 87-regular, but certainly 89-regular. I can't see a reason to run it on more than 91, even if you want a margin of "safety."
Remember, these engines were not spec'ed to run retarded from the factory - they were supposed to run with a correct amount of advance, so advancing it more and using premium probably won't get you much , if anything.
MDchanic is offline
haggfan
February 22nd, 2015 01:47 PM
navvet
August 26th, 2013 07:06 PM
May 7th, 2013 12:01 PM
CutlassLegend
August 6th, 2011 02:53 PM
cogaritis
July 13th, 2011 07:57 PM
Quick Reply: olds 330 fuel difference in octane
