Oil Pressure Sensor
Old Oct 12, 2010 | 06:31 AM
Oil Pressure Sensor
Hello,
I noticed the other day that my oil pressure sensor is leaking like a sieve. There was a puddle the size of a silver dollar after about 5 minutes of idling.
I bought a replacement from the auto parts store. When I install it do I use teflon tape on the threads?
I want to make sure it doesn't leak anymore, but I don't want to install it incorrectly. I'm not sure if the threads are leaking now, or if it is the old sensor. I do know that the old sensor installed correctly when I originally assembled the engine (it didn't cross thread). I didn't put teflon tape on it originally.
Any advice is appreciated.
Old Oct 12, 2010 | 07:03 AM
citcapp's Avatar
I use teflon tape and have had no leaks. I like it better then thread sealing compound plus it is easier to get the fitting out at a later date as it does not seize in place
Old Oct 12, 2010 | 07:48 AM
It's a pipe thread (a tapered, self-sealing thread).
They always get Teflon tape.
Machine threads (like compression fittings) do not.
Old Oct 12, 2010 | 09:17 AM
rocketraider's Avatar
Oldsdruid
Be aware that teflon tape or pipe dope can affect the ground path for the sender resulting in it not working. It will still bulb test with ignition switch on as it grounds thru the ignition switch for that.
Old Oct 12, 2010 | 10:23 AM
Thanks for the info gents. I will install it and keep everyone updated.
Old Oct 12, 2010 | 10:57 AM
Not to be a troublemaker, but have you seen that, or is it theoretical?
I've never seen threads wrapped with a reasonable amount of Teflon tape (1-2 turns) where the metal didn't show through somewhere after screwing it in.
Old Oct 12, 2010 | 12:19 PM
Blk71SX's Avatar
there will be enough metal to metal contact even with tape to provide a ground. looking from the threaded end, wrap clockwise. wrapping the other direction can wad the tape making it less effective
Old Oct 12, 2010 | 12:31 PM
wrapping the other direction canl wad the tape making it less effective
Yes indeed. I'm always careful when I install teflon tape to make sure it is installed correctly. My old man taught me well.
Old Oct 13, 2010 | 06:30 AM
I replaced the oil pressure sensor last night at 2100. I used teflon tape and cleaned the threads thoroughly. I let the car idle for 10 minutes and it didn't leak!
When I removed the old sensor I noticed that the top of the sensor was saturated with oil, apparently it was leaking.
$7.00 to fix an oil leak is a pretty good deal. For awhile I was afraid the rear main seal was leaking and getting the bottom of my engine oily. I'm glad I didn't have to remove the engine.
Old Oct 13, 2010 | 06:44 AM
Oldsguy's Avatar
Past Administrator
Yeah, good work!
Old Oct 13, 2010 | 07:59 AM
They leak around the crimp between the metal and the bakelite on the top.
Just replaced mine with one from eBay - Standard Auto Products, NOS in the box for $2.50, had it thrown in with something else I was ordering. Previous owner had let it pi$$ all over the engine for years. Great rust preventative!
Old Oct 13, 2010 | 08:06 AM
I just bought mine from O'Reillys. It works great now!
Old Oct 13, 2010 | 08:09 AM
Yep,
You was drug up good.
Old Oct 13, 2010 | 11:37 AM
mike's88's Avatar
It's a little late, seeing you already replaced and no leak. I prefer to use teflon paste, this way, I only put a little dob on the threads, as you screw it in, it spreads around on the threads, and no chance of a loose piece of tape getting in the engine.
Old Oct 13, 2010 | 11:43 AM
This is something I thought about. Fortunately, I only used a small amount of teflon tape. FWIW, I never use teflon tape on transmission cooler lines for the same reason.
Old Oct 13, 2010 | 08:04 PM
BILL DEMMER's Avatar
Just the facts...
i'm surprised the new piece didn't have a sealant on the threads already.
myself, i would use a liquid sealant. if using teflon tape, i space it back one thread from the end to eliminate the possibility of stragglers.
bill
Tim305
Apr 29, 2014 03:36 PM
dacutty
Mar 28, 2014 09:01 AM
nanardos
Sep 1, 2013 09:41 AM
foreverolds
Dec 1, 2012 07:07 PM
ej69
Sep 14, 2009 07:20 AM
