Oil Pressure Sender Switch
Hey guys on my 1964 oldsmobile f85 deluxe the oil pressure switch is leaking oil. Should I just buy a cheap one or should I look for a NOS on ebay? If anyone knows where I could get a nice one that would be helpful. Thanks, kevin.
this one says 56-63 then says 1964 so is this the one that i'd need? http://www.ebay.com/itm/NOS-1956-63-...86665b&vxp=mtr
Why are these your only choices? Can't you go to an auto parts store and buy a new one that's not "cheap?" That's all I've ever done over the years, and I've never had a problem.
I'm not sure what you mean by "nice one." These are not gourmet items. They're not something that's going to dress up your car. Get over to NAPA or Carquest or whatever, spend $12 or whatever, and get one.
No need to go NOS. In fact, I'd be suspicious about the reliability of a part like this that's been sitting in box for 50 years.
x2. That is why there are so many auto parts stores and not just dealership parts counters out there in the world.
You know how sellers jack prices just because a part ( that May or may not work ) is NOS. Think PT Barnum and you too could be an NOS parts seller.
I got a cheap replacement at Pepboys which worked fine, and then just decided to get a pressure gauge and had the whole thing installed in about an hour.
HINT: My gauge came with a thin white curly tube, looks terrible. So after running it from the replacement fitting on the front of the block where the pressure sensor was, through the firewall to the gauge, I got some gas line hose and split it down the middle and shoved the curly line into it to drape back across the manifold to the firewall. Totally unnoticeable and fits in with everything else, all other hoses.
StickW31
January 7th, 2013 08:51 AM
