Odd no start issue
Old Apr 29, 2013 | 02:28 PM
devmar07's Avatar
Odd no start issue
I went to take my 72 cutlass out of storage turned the key turned over the engine fired I let off the starter and it died. If I put a jumper from the distributor to the fuse panel it will run all day. I have power to the distributor with the key on just can't figure why it won't stay running
Old Apr 29, 2013 | 02:52 PM
You have HEI, right?
There is a problem in the wire between the ignition switch and the HEI.
The bypass wire from the starter solenoid to the coil (now the HEI) is powering up while cranking, but once you release the key, you're on the running circuit, which is not providing enough juice.
Either the original resistance wire is still hooked up (it shouldn't be) and isn't supplying enough current (probably because of a bad or broken connection), or there is some other break in the line.
Since HEI needs a full 12V to run properly, you need to check to see whether someone else already ran a 12V wire to replace the resistance wire, and their connection failed (ie: wires twisted together, not soldered), or whether there is a problem with the original wire.
The heavy pink wire from your ignition switch is the one you need.
Old Apr 29, 2013 | 05:46 PM
devmar07's Avatar
I do have hei and I did replace the resistance wire I had the car out last summer with this setup with no issue I will check my connection at the fire wall for 12v. Is it possible that the ignition switch is bad or would it not start at all
Old Apr 29, 2013 | 05:57 PM
Yes, a bad ignition switch is also a possibility, but it doesn't happen much.
Old Apr 29, 2013 | 06:13 PM
I agree with Eric, you have a problem with what ever you are using to supply your HEI, as you stated already a jumper will allow it to run all day.
Old Apr 29, 2013 | 07:26 PM
devmar07's Avatar
I will check the wiring for sure then thanks guys
s i 442
Apr 5, 2015 07:11 AM
colemane
Apr 13, 2013 01:19 PM
celodog
Brakes/Hydraulic Systems
Jan 1, 2013 09:58 AM
Destructor
Oct 22, 2010 05:35 PM
rrielley
Sep 1, 2008 03:00 AM
