OAI routing from flapper 70 W-30 ??
from the port on the manifold it goes to the T up by the breather then to the door motor. the other side of the t goes to the vacuum switch on the breather base by the filter. from there it will go to the vacuum door on the snorkel.
here is a page from the assembly manual.
05-16-2010073340AM.jpg?t=1274010025
I own a 70 w-30 and the diagram jensen posted here is exactly how mine is set up. What may not be exactly clear is where the hose connects to the carb. If you are still uncertain I can take pictures of my set up.
Hey, Jensen - where do u get such a clear and precise manual ???????
http://www.fusick.com/catfile/Catalo...Layout%203.pdf
jensenracing77
September 30th, 2012 03:31 PM
OLDSmobility
October 8th, 2010 05:54 AM
