OAI routing from flapper 70 W-30 ??
Old May 15, 2010 | 10:34 AM
442oldslawyer's Avatar
Think I am missing the inlet on front of manifold. Where does the hose go from the vacuum opener on top of Air cleaner ?
Old May 15, 2010 | 01:52 PM
My442's Avatar
The inlet is a 90 degree fitting behind the carb on the drivers side.
The OAI vacuum is tee'd off the vacuum line from the 90 degree fitting to the air cleaner.
Make sense?
Old May 15, 2010 | 02:26 PM
The tee to rear of the manifold to 90 degree , top of tee to the vacuum , where does the other hose go?
Old May 15, 2010 | 04:57 PM
Hairy Olds's Avatar
Shoveling Snow
If your talking about the larger hose, that's a drain hose for water.
Old May 16, 2010 | 03:33 AM
There are 3 hoses off the tee. one to vacuum opener on top of air cleaner. one to rear 90 degree and third to where?
Old May 16, 2010 | 03:48 AM
Bunser's Avatar
It should go to the "TCS unit?" located on the passenger's side of the carb. (At least, that's where mine goes.) Hope this helps.
Old May 16, 2010 | 04:41 AM
jensenracing77's Avatar
from the port on the manifold it goes to the T up by the breather then to the door motor. the other side of the t goes to the vacuum switch on the breather base by the filter. from there it will go to the vacuum door on the snorkel.
here is a page from the assembly manual.
05-16-2010073340AM.jpg?t=1274010025
Old May 16, 2010 | 08:40 AM
Thanks for the diagram. Brought is back. Old me don't need to keep doing this .
Old May 16, 2010 | 04:42 PM
coltsneckbob's Avatar
I own a 70 w-30 and the diagram jensen posted here is exactly how mine is set up. What may not be exactly clear is where the hose connects to the carb. If you are still uncertain I can take pictures of my set up.
Hey, Jensen - where do u get such a clear and precise manual ???????
Old May 16, 2010 | 07:15 PM
you can get them from fusick. it is part number B70AM. it is the 1970 assembly manual
http://www.fusick.com/catfile/Catalo...Layout%203.pdf
jozw30
Jul 25, 2015 09:00 PM
1carsick
Jan 16, 2013 04:27 AM
jensenracing77
Sep 30, 2012 03:31 PM
spasco442
Nov 24, 2011 04:54 PM
OLDSmobility
Oct 8, 2010 05:54 AM
