OAI parts: 350 v 455
Old March 7th, 2011, 08:17 AM
VikingBlue's Avatar
I see several vendors for OAI stuff show some differing parts for the 350 than for 455 motor. How are they different ? Will look to buy OAI stuff this year on this forum or CL, etc. and I need to know what I buy can be used.
VikingBlue is offline
Old March 7th, 2011, 12:18 PM
stevengerard's Avatar
I am pretty sure most of it is the same, the top assembly with the flapper is at least. I'll have to check on the air cleaner base but I thought that was the same - main difference is the foam seal is thicker for the 350 as it is shorter.
stevengerard is offline
Old March 7th, 2011, 12:28 PM
svnt442's Avatar
I think that's the only difference. The foam needs to be thicker on the 350 due to the shorter deck height.
svnt442 is offline
Old March 7th, 2011, 12:45 PM
Correct. The foam is taller. That's the only difference.
joe_padavano is online now
Old March 7th, 2011, 01:53 PM
VikingBlue's Avatar
Thanks fellas....
Old March 7th, 2011, 04:32 PM
jensenracing77's Avatar
the 350 base has a rubber plug in the driver side hole for the crank case breather and the 455 had two breathers, one to each valve cover. the base was the same though.
jensenracing77 is offline
joesw31
October 26th, 2014 05:39 AM
1carsick
January 16th, 2013 04:27 AM
gearheads78
February 29th, 2012 08:11 PM
sx455raidercelticfan
December 21st, 2010 05:19 PM
October 18th, 2010 07:26 PM
Quick Reply: OAI parts: 350 v 455
