OAI Hood Twist Knob Installation
Old December 26th, 2017 | 03:54 PM
sleeton's Avatar
OAI Hood Twist **** Installation
My wife was kind enough to buy me a twist **** kit with the lighter springs for my Glasstek OAI hood. Unfortunately the kit came with no instructions. I have most of the install figured out buy I am not sure about a few parts. It appears the twist ***** on the bottom of the round disk looking piece that is below the spring I am to remove a round piece of plastic which then leaves behind an adhesive sticky part that I presume will allow the twist **** to be attached to the hood. Currently my good has a round disk that looks like a large thin washer already in the recess hole where the twist **** is to be placed, is that correct?
Also included in the kit were two of the pieces I have attached a photo of, what are these for as I have no idea?
Need help!
Old December 26th, 2017 | 04:40 PM
2blu442's Avatar
Its been years since I installed a set of these. But I'm pretty sure your right about the thin washer looking piece having adhesive on the back side and going under the big chrome ****, against the hood. The metal tabs in your picture need to be bolted to the underside of the hood. Did you have fasteners with them? I'll see if I can come up with a photo for you. John
Old December 26th, 2017 | 04:50 PM
2blu442's Avatar
Yes, the washer thing goes under the ****, with the spring between them. Then the tab attaches to the underside of the hood as I'd thought. Here's some pictures to help see what I'm describing. John
Old December 26th, 2017 | 08:16 PM
sleeton's Avatar
2blu442 in the second picture that you sent, the tab piece you mention only has a half of a notch yet the twist **** has two "ears" and needs two notches, what am i missing?
Old December 26th, 2017 | 08:17 PM
sleeton's Avatar
the screws that hold those little retainer plates in, are those just self-tapping screws or maybe sheet metal screws that a pilot hole is pre-drilled and then the screws are screwed into the hood?
Old December 26th, 2017 | 08:45 PM
2blu442's Avatar
Sorry, its a factory hood and already had the holes in it. Yes they are sheet metal screws, I don't remember for sure, but don't think they were self tapping. The tabs, put them through the pin before bolting them on the hood, That way you put one end of the ear through, rotate it and get the other end through. Its been 35 years since I worked on this hood but am pretty sure that's the way it was done.
Old December 27th, 2017 | 03:25 PM
sleeton's Avatar
2blue442 can you send me pics of the piece that is bolted on the the radiator support I believe that the twist **** actually secures into, I take it there are holes that the anchor pieces are bolted into.
Old December 28th, 2017 | 02:41 PM
2blu442's Avatar
Sorry for the delay, these pictures are on a 1970. I'm not sure if 1971-72 are different, but I believe the key is the hole where this car has the hood bumpers mounted. The car had some custom work done on it in the 1970's so I can't say for sure if this was the way it came or not. Let me know if you have any more questions after this. John
Old December 28th, 2017 | 02:44 PM
2blu442's Avatar
Then here's a 1972 core support. It looks like the hood bumper is in a different location, but it also has the same holes for the hold down brackets. I think the key will be to start with the hole on the top, that has the depressed area. Then line up the other two holes after that.
Old December 28th, 2017 | 03:33 PM
sleeton's Avatar
Ok thanks for the help
Old December 29th, 2017 | 06:14 AM
WTHIRTY1's Avatar
Escape From The Ordinary
Make sure that the push pin doesn't shift. I've had that happen a time or two, and it makes popping the hood somewhat challenging.
Octania
August 30th, 2014 05:52 PM
TripDeuces
November 27th, 2012 06:57 PM
December 10th, 2011 05:23 PM
easytobedead
February 7th, 2010 08:20 AM
Want-A-Vert
May 7th, 2007 10:20 AM
