Sales twist: J heads "high torque" units!
Old Aug 30, 2014 | 04:52 PM
Octania's Avatar
http://www.ebay.com/itm/Oldsmobile-4...-/301216787402
"Oldsmobile 455 Engine Mild Street/High Torque Build High Compression.
375HP & 500 ft lbs Torque!
1975 455 Block I.D. 396021F with "J" High Torque Cylinder Heads and "N" Nodular Iron Crankshaft
Note: All Engines are Test Run for at least 30 Minutes to Check for Coolant & Oil Leaks, Oil Pressure and Proper Camshaft Break-in Process, Before Shipping.
New SpeedPro .030 Oversize Cast High Performance Lightweight Pistons 9.7:1 Compression Ratio. Premium 91 Octane Fuel or Higher Required.
New SpeedPro Moly Piston Rings. .030 oversize
New ARP High Performnce Connecting Rod Bolts.
New Edelbrock 2152 Performer Plus Camshaft. Specs:Lift .472 Intake/.496 Exhaust, Duration 288 Intake/ 298 Exhaust, at .050 Lift 214 Intake/ 224 Exhaust.
New Edelbrock Hydraulic Lifters
New Melling High Volume Oil Pump with Bolt-On High Volume Pick-Up screen.
New Michigan/Clevite Mains and Rod Bearings Standard Size Rods/Mains.
New Felpro/Victor Gaskets.
Stock Cast Iron Intake Manifold.
Mondello Oil Restrictors Installed for Extra Engine Bearing Longevity/Durability.
New Comp Cams Double Roller Timing Chain
New Water Pump
90 Day Warranty included if sold within the 100 Miles of Zip 60083 and is used for street application
Fits All Oldsmobile Rear Wheel Drive Vehicles 1964-1990, and most other GM RWD vehicles with minor modifications.
Fits All Toronado's 1966-1978
Also a great motor for Rock Crawlers.
Will paint this engine any color requested.
Roller Rocker Arms and/or Aluminum Intake Manifold are available at extra cost.
Please Look at my other engines for sale here on Ebay, click on "view sellers other items"
Will Ship Via ABF Freight Weighs Approx 600.00 lbs.
Will work with any GM Automatic transmission with BOPC(Buick,Olds,Pontiac,Cadillac) bellhousing bolt pattern and some manual transmissions with BOPC bolt pattern or Adaptor Plate."
monzaz
Sep 13, 2013 10:33 PM
TripDeuces
Nov 27, 2012 05:57 PM
easytobedead
Feb 7, 2010 07:20 AM
Want-A-Vert
May 7, 2007 09:20 AM
