Oai
Old Jun 1, 2015 | 06:12 PM
Gary M's Avatar
Oai
I paid the big bucks for the vacuum operated air cleaner but now it does not close the flapper at idle. Any way to test the vacuum actuated pot mounted in the OAI top?
Old Jun 1, 2015 | 06:28 PM
Octania's Avatar
http://cgi.ebay.com/ebaymotors/BLUE-...item3cf700ddc5
Old Jun 2, 2015 | 05:47 AM
There are only four things that can prevent the flapper from working:
1) Binding flapper hinge (unlikely and very easy to check)
2) Vacuum actuator not connected to full time manifold vacuum. Use a vacuum gauge to verify that the hose is connected to manifold vacuum and not ported vacuum.
3) Insufficient engine vacuum (the tapockia-tapockita-tapockita idle would likely give this away)
4) Bad vacuum actuator. The even easier way to test this is to push the actuator rod all the way into the actuator, hold your finger over the vacuum port, and release the actuator rod. If the rod comes all the way back out (a small amount of movement is to be expected), the actuator is bad.
Old Jun 2, 2015 | 06:17 AM
pogo69's Avatar
morgan
attach a hose to the vac motor and suck on the hose and if your tongue sticks for a while you have a good motor
Old Jun 2, 2015 | 03:39 PM
Gary M's Avatar
Vacuum actuator shot. Thanks for the tips. Called Parts Place.com where I got it on Sept 19, 2013. Asked about warranty and was told even the original equipment ones only lasted a year or so. I put under 2000 miles on my car so I wont be hurrying back to buy more. At least from them anyway.
Old Jun 2, 2015 | 04:42 PM
Well, the one on my 70 is still original...
Unfortunately, I'll bet all the repro vendors get them from the same factory in China.
Old Jun 2, 2015 | 04:50 PM
Had one from a W30 along with the hood etc. that came from a junkyard, lasted the two years that I had it, I'm quite sure that they last longer than a year. Nothing like a vendor making an excuse for crap. I probably should go out into the garage and check the one that's been hanging there for 20 years.
Old Jun 2, 2015 | 04:56 PM
Gary M's Avatar
There is a possibility that the one I got was just a lone defect but his going straight to "they only last a year" kind of ruined that hope.
sx455raidercelticfan
Dec 21, 2010 05:19 PM
Oct 18, 2010 07:26 PM
71cuttyS
Dec 4, 2007 09:49 AM
shaks 442 clone
Sep 12, 2007 02:45 PM
chevelle_ss
Feb 1, 2007 08:31 AM
