Noob bearing question
I always thought you had to replace the race, too, and do, if they're bad, but, since all the manufacturers use the same angles now, I use the ones that came with the new rotor or drum.
No comebacks in 30 yrs.!
Yeah I know... and new rotors come with races already installed. And I have just swapped bearings without a problem but I would say it is best to replace as a set. My opinion only....
Bearings and races should be replaced together, they are matched sets and are packaged together. What ever the wear pattern was on your bearing, the race will have the pattern also.
I do not interchange bearings and races of different brands.
Do you value / LOVE your car???
Rather than order Chinese garbage from Rock Auto -- why not treat yourself to N.O.S. ++ U.S.A. ++ made wheel Bearings & seals --- no wobble or warpage...........
Call me -- Craig -- 516 - 485 - 1935.........New York.....![Smile](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
I just ordered the bearings, as well as a new wheel seal and some other non-related doodads. Any advice on how to best drive out the old races? I've heard tell of a race removal tool. Any thoughts?
Just put the rotor down on the floor and whale on the back of the race with a sledgehammer and a drift.
And should I completely clean out the old hubs before putting the new bearings/races in, or just not mind it, as long as the grease is still clean?
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
At the very least, completely wipe out any old grease and dirt.
You could clean it with thinner as well if you wish, but that isn't essential, and can sometimes introduce grit if it runs over dirty outside surfaces first.
Remember, these bearings will be turning at about 800RPM at 70mph, and will turn about 38 million times in 50,000 miles, so any little piece of sand has the chance to do plenty of damage.
Flye
Drivetrain/Differentials
July 30th, 2009 10:24 AM
