Newbie question 0- what kind of gas?
Old May 13, 2014 | 03:49 PM
Big Blue 65's Avatar
What do people recommend for a 455 Rocket? Regular or premium. Thanks to everyone that is answering all my newbie questions about my new ride that I've always wanted since I was a kid but don't know much about!
Old May 13, 2014 | 04:16 PM
I would suggest the highest available octane you can get in your area.
Old May 13, 2014 | 05:14 PM
Too many variables and not enough information to answer the question.
Depends upon the year, if it's been rebuilt or not, and the ambient temperatures.
A factory 71-76 8.5:1 engine would probably run fine on low octane fuel during cool/cold weather.
An early factory 10.25:1 compression or rebuilt high compression engine running in Phoenix 110+ temps during the summer would likely need as high octane fuel as you could find.
Old May 13, 2014 | 08:15 PM
Mine is a completely stock all original 1968 Olds 98 with Rocket 455
Old May 14, 2014 | 08:55 AM
Professur's Avatar
Not relevant to your motor, but I've been running 91 in my 307 all winter to get away from the corn ****. Costs a little more, but I've run the numbers and I am getting better mileage, enough to offset the cost and more. Most if not all 91+ fuels don't have any ethanol added. As with all things, just my observation. Your mileage may vary.
Old May 14, 2014 | 12:34 PM
All fuels in my area have ethanol added. I believe your engine has a compression pressure of 180-190 lbs, it needs higher octane than regular.
Old May 14, 2014 | 03:11 PM
Sugar Bear's Avatar
A 1968 all original 455 4 barrel is a high compression motor. I would ONLY run it on premium and still be on the alert for detonation/pinging. Some of the original fuel caps had a red decal on them stating premium fuel only as did some of the air cleaner decals.
Think about replacing the timing chain and gears as maintenance if it has not been done already. The plastic from the old cam gear breaks off and can clog/restrict the oil pump intake or the chain can jump on the worn cam gear without warning and cause other engine damage.
72Cutlass
May 24, 2021 07:24 AM
orsogrigio
Oct 30, 2013 03:23 PM
The_Jeremiah
May 9, 2008 05:54 PM
BIGJERR
Jan 22, 2008 07:19 AM
GoldOlds
May 20, 2007 09:17 AM
