New water pump leak/weep
It is normal for a new water pump to have a very slight coolant weep (dampness there at the weep hole) after a few test drives. No visible coolant on cank pully etc, I have been checking the weep hole area after each test drive, after 1st new pump clearly leaked there after first test drive. This 2nd replacement pump, I noticed is was wet/damp to touch and whatever leaked took the paint off below the weep hole, so it leakng something. It is odd , it is not enough to look like green coolant, it just feels wet/damp, but it has that slick coolant feel, no smell because of the small amount. Is this weeping from break in? My thought...a leak is a leak or it will be become a bigger leak soon thanks.
If it’s leaking, the seal is bad.
I worked at auto parts stores for years in school (80s) and I have never heard of weeping being a normal occurrence with new pumps.
What's the condition of your timing cover? These are stamped steel and have a tendency to pit over time below the pump. It's possible yours has some pits around the perimeter of the gasket and you're not getting a good seal.
Walterdurbin
Tech Editor's Desk
May 12th, 2016 04:32 PM
