New Parts ?
Old Apr 7, 2014 | 03:11 PM
76olds's Avatar
Hookers under Hood
New Parts ?
I finally got the parts I ordered, Powermaster mini starter, milodon aluminum water pump, along with an accel coil and module, I must say the water pump looked much shinier in the picture. Its very dull but its much lighter than the cast iron pump.
My ? is.... the water pump says to use a high flow thermostat but I've heard they are NFG. What do you guys think?
Old Apr 7, 2014 | 03:46 PM
I like the Stant Superstat.
Old Apr 7, 2014 | 04:21 PM
76olds's Avatar
Hookers under Hood
I will check them out , I Put a Robertshaw 195 in it last summer when I put the intake on, I MAW go with the stant superstant . Thanks Eric !!
Old Apr 7, 2014 | 04:32 PM
The Robert Shaw should be fine also.
Old Apr 7, 2014 | 04:40 PM
76olds's Avatar
Hookers under Hood
It likely would be but I never heard of stant, I had a looksie at the reviews and they are very good. So I'm going to go with the stant .
Put-r-ther I like your choice !!!
Old Apr 7, 2014 | 09:59 PM
Why do you want to replace the Robert Shaw thermostat? I thought it was the preferred high flow thermostat.
Old Apr 7, 2014 | 10:43 PM
76olds's Avatar
Hookers under Hood
I don't recall if it was the high flow.
Sickle
Aug 31, 2013 08:28 AM
ah64pilot
Sep 19, 2012 10:55 AM
ah64pilot
Aug 17, 2012 02:36 PM
skinny
Apr 23, 2007 02:46 PM
redrumloa
Mar 10, 2007 06:45 PM
