New Fuel Sending unit Reads Incorrect 70 Cutlass
Installed new tank and sending unit. I put fuel in it, had ¼ tank of gas, ran the car up put to the station, put in $25 worth, which was 9.6 gallons and gauge went to full, which it should not have...based on the gallons..tank spec says it is a 20 gallon. I used the old unit and checked the gauge.. it is working fine. New gauge is reading 87 ohms, spec list 0-95 ohms. I did check the new sending unit before installing it ...hooked to the gauge and it read correctly. However If the arm angle is off then it would read incorrectly..., so either way I think I have a bad sending unit
... Has anyone ran into an issue like this?
thanks
thanks
You may not have any thing wrong at all. Drive it and monitor your consumption over at least one more full tank. I don't think you have any thing to worry about right now.
What I'm saying is a quarter tank on the guage may not equate to five gallons. It probably has more gas in it, more like 8 gallons.
Next time, fill it up all the way. See just how far full really is on your guage. Its likely to go a little past F.
The issue is that most of the gauges were not very accurate and it depends on the contours of the tanks. Some models would ride on full forever and then slowly drop to 1/2, and swiftly go to E. The gauges would swing between 1/4 and 3/4s. Once you get the hang of how your gauge works, then you adjust your fueling habits.
It's just a float, half may only mean half way from the top of the tank to the bottom of the tank but may not represent actual volume. A home heating oil tank is similar.
Mine flat quits at 1/8 mark on the gauge. Found this out in Montana and had it towed to a shop thinking the fuel pump had died. I would run it down till I was very uncomfortable( with a backup can in the trunk) and make a mental note how far you can go, depend on that....Tedd
I've learned that when the gauge reaches empty,
I still have approx. 5 gallons, or 1/4 tank in a 20 gallon tank.
When I fill up, the gauge only goes to 3/4.
Apparently the calibration is off by a 1/4 tank on the new tank unit.
A little irritating, but, at least I know my fuel status now.
I'll live with it 'til the next time I jack the rear of the car up.
Looks like the reproes are having a problem with calibration.
Wow, both my '70 and '71 seemed very linear from F to E, so much so that I could use the gauge increments to judge how many more miles I could drive before needing fuel.
I stand corrected. This morning I pumped the tank out until it read 1/8th. So I thought I'd drive around our [country] block a couple of times to run it out. I made it about 150 feet. Mine runs out at 1/8th tank. That won't do.
Yeah, it is good to know when you really, really need to find a gas station!
It also sounds as if your pickup could use some calibration. Both of my cars had about 2 gallons left when the needle hit E. I confirmed that more times than I care to say.
I've never run mine out of gas. My needle as most in that era will have wide swings as it drops down from 1/2 to E when making turns or braking. My theory of these older cars when the needle stops moving your out of gas. With that said, I usually fill up when the needle drops below 1/2.
Could be I snagged it when I was pumping out the tank. Is there any way to know what the orientation is supposed to be? I could see this being a very long, painful process. Bend, reinstall, install tank, add gas, pump out the gas, remove tank, repeat. Maybe I'll compare to Allan's pics in his Another MAW Disaster thread.
Had the same thing happen too on my 68. Replaced the tank and sending unit. It would read a little over half a tank when it was full. I dropped the tank and bent the float. It now reads just over 3/4 when full. Haven't had the heart to pull it again. Sure would be nice to have an access panel in the car to adjust this!
Craig
Craig
I got my tank off and sending unit out. And guess what....it works! Ugh. Must have been a bad connection. With the unit sitting in the trunk, I hooked it up, grounded it, and played with the float. All the way up reads a bit over "F". All the way down nails the "E" right on. Problem is the filter sock is torn and the main cap and ring are VERY corroded. I went ahead and ordered a new one from Inline Tube's eBay store. I hope it's as accurate.
Uhhh...the fact that it works fine out of the car means nothing. I tested my repro before I put it in. It worked perfect. I didn't check the arm against my original arm. It doesn't read full like it should but close enough.
Lol, yeah, no, I mean i realize it depends on how it hangs in the tank. I was just excited to see the needle actually move off of the hot light. I'm keeping the old one to compare with the new before I install it.
KDW
March 2nd, 2015 04:17 PM
68RocketAction
December 18th, 2014 11:19 AM
Oldskool84
October 10th, 2014 06:21 AM
