Neutral safety switch
Old Jun 25, 2018 | 08:51 PM
servexcell's Avatar
iam replacing the transmission in my 68 from a jet away to a 400th.
it is automatic floor shift , is the neutral safety switch the same for both transmission or do i need one for a400th
thanks Bruce
Old Jun 26, 2018 | 09:02 AM
thanks Bruce
The NSS and kickdown switch are both the same for TH400 and Jetaway. Naturally you will need to move the crossmember, get a correct TH400 driveshaft and front yoke, and change the front and intermediate e-brake cables due to the crossmember move.
Old Jun 26, 2018 | 04:02 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Console car or column shift?
Old Jun 26, 2018 | 05:07 PM
thanks Bruce
Old Jun 27, 2018 | 05:30 AM
Dam old refrigerator eyes...dauh. Consol sw will/may need adjusting. The shift plate will need to be modified in order to get all the way down into 1st gear. The detent will need to be replaced with a 3 speed or the 2 speed can be modified with a file or rotory rasp to create the 1st gear detent.
allyolds68
Jan 22, 2014 07:11 PM
James Wilson
Mar 6, 2013 12:57 PM
OKIEOLDS
Aug 8, 2011 05:17 PM
Olds luvr
Aug 16, 2010 05:15 AM
Flye
Mar 30, 2009 03:45 PM
