need help on cam identify
Old Feb 6, 2017 | 02:52 PM
w30hurstolds's Avatar
took this cam out of my car. Need help to identify number on cam is 389410
Old Feb 6, 2017 | 04:46 PM
That's a standard GM casting number for Olds cams.
It could be a wide variety of cams.
If it's a GM cam, and it hasn't been reground as something different, the chamfers on the front of the cam may be able to provide information. Take a picture of the front of the cam, with the lighting good enough that the chamfers are clearly visible.
Old Feb 6, 2017 | 06:34 PM
cam
hope this helps
Old Feb 6, 2017 | 07:12 PM
My feeling is that what I'm seeing is a single chamfer going about 300° around, sparing the ~60° starting at the V-shaped notch and continuing clockwise, which would indicate a 400 or 455 M/T cam (except W30) in 1968, '69. and '70 (and maybe some others - I'm not checking everything).
This would be a 1966-'69 393859 or a 1970 406768, and possibly others.
We could be more sure if you could take an evenly lighted photo of the whole face of the cam, straight-on (this picture is taken from an angle toward the short side of the checkmark-cutout and cuts off a portion of the cam).
Here's the Cam ID chart from the '68 CSM:
Old Feb 6, 2017 | 07:42 PM
cam
this cam came out of my 69 w-30
Old Feb 6, 2017 | 07:44 PM
cam
pictures
Old Feb 6, 2017 | 08:10 PM
svnt442's Avatar
From the 1970 service manual...
Almond900
Aug 11, 2016 06:58 AM
83hurstguy
Aug 15, 2015 08:56 AM
Mad Mex
Oct 6, 2014 11:52 AM
buzzybee
Mar 24, 2014 05:34 PM
maskinen
Apr 8, 2008 05:16 AM
