Need help 1967 dash a/c vent ball location
Old August 19th, 2024 | 07:54 AM
oldsrush's Avatar
Gearhead
I'm in the process of installing a/c on my 67 442 and will be installing factory a/c vent ***** in each end of the dash. Because of the slanted and curved area it will be difficult to layout the hole for cutting. If someone has a dash with the ***** currently removed and would take a picture of the hole and give me the size or a pattern I will greatly appreciate it. James
Old August 19th, 2024 | 09:52 PM
It's on the dash frame, not the dash itself, as I am sure you know. I do not know if those cars used the same sheetmetal for AC vs non cars and the difference was only the presence of holes or if there were differences in contour and extra bracing.
Mine is not apart. Here is the best picture I can find. It APPEARS that the sheet metal is the same, and it attaches to just the sheet metal, and it will work. It looks like there is only one spot it can go. Dimension your AC ***** into an ellipse. Make a template. It appears that the amount of sheet metal at 9 oclock, 1:30, and 4:30 are the same width. You should be able to locate it. 9 oclock might be a bit thicker. There isn't any difference in the dash pads, so I hope it is the same frame.
Old August 20th, 2024 | 07:35 AM
oldsrush's Avatar
Gearhead
Thanks Koda, at least that shows what an odd shape I'm dealing with. Looks like a horizontal tear drop with ears. It's not going to be easy from scratch, the studs on the bezel will not let me hold it in place to draw a pattern. My thoughts are to take a cardboard tube and miter it to fit the curve and angle and go from there. If I could find a pattern it would save me a ton of work.
Old August 20th, 2024 | 04:44 PM
oldsrush's Avatar
Gearhead
I played around with making a templet today on the passenger side. First thing I realized is that the factory made a much larger hole than required looking at Koda's picture. It's almost as big as the outer edge of the bezel. I going to do my pattern with a smaller hole allowing some room for error.
Good picture showing location I found on internet.
Old August 21st, 2024 | 03:20 PM
Goldiewilson4mayor's Avatar
Goldiewilson4mayor
templete
When, i add the ac/ vent to no a/c cars I make a pattern out of manilla folder and tape it to the dash , allows for the curve and i sneak up on the fit , , just my 2 cents
Old August 21st, 2024 | 06:51 PM
oldsrush's Avatar
Gearhead
Didn't get a chance to work on it today but did notice one weird thing. The point of the "tear" is not on the centerline of the tear drop adding more difficulty to making a pattern.
Old August 25th, 2024 | 04:25 PM
oldsrush's Avatar
Gearhead
Got this far, now working on my nerves to make the cut. Made my templet from some thin aluminum that worked pretty good. The outer edge is same as the bezel and curved to fit the contour of dash. The plastic ball housing slips thru the ring from the inside.
Old August 26th, 2024 | 09:31 PM
dennis_30281's Avatar
I did the same thing on my 62 Starfire except I had the dash out of the car. There was a template engraved on the back side of the dash where the vent goes, made cutting the hole easy.
Old August 31st, 2024 | 08:12 AM
oldsrush's Avatar
Gearhead
Got both sides done. It was a very tedious job to say the least. On the passenger you can remove the glove box and gain access to insert the ball housing from the back and tighten the nuts on the bezel studs. On the drivers side I looped a long ty-rap thru the ball and pulled the housing up in place and pulled the bezel up tight with a block of wood. With seat removed you can lay under dash and tighten nuts on studs. You need three arms and one triple jointed arm otherwise.
Old August 31st, 2024 | 10:37 AM
Looks terrific James, great work as always! 👍
Old August 31st, 2024 | 11:00 AM
Certainly will pass for factory.
Old August 31st, 2024 | 04:21 PM
oldsrush's Avatar
Gearhead
Thanks, when I finish I'll pass all my notes for you to get started on yours.
Old August 31st, 2024 | 04:23 PM
oldsrush's Avatar
Gearhead
Thanks Koda, that was my goal. Here is another factory looking touch....
Old August 31st, 2024 | 05:30 PM
No thanks, I don't want to be handicapped by all that extra weight! You've already got an unfair advantage with that beastly 455, while I'm stuck with my paltry 400.
Old August 31st, 2024 | 06:10 PM
If you had a G 400, you'd have a point. The E 400 could hang out around 6k and the 455 had more lower end torque. He might beat you off the line, but I think you would win the quarter.
Old August 31st, 2024 | 06:40 PM
It would be interesting for sure, lots of factors like "add-ons", gears, etc.!
Old September 9th, 2024 | 05:23 AM
CatherineBennett's Avatar
Spoiler
​​​​​​​Thanks for the picture.
lala5818
November 22nd, 2022 02:38 AM
6D7 442
July 21st, 2022 01:30 PM
jimg6320
May 17th, 2021 08:00 PM
fourtwenty
February 8th, 2011 06:45 AM
Kace
May 22nd, 2010 05:36 AM
