Need advice on lifting assembled 455 short block
Old September 15th, 2018, 10:38 AM
BondAR's Avatar
Hey guys, looking forward to getting a 455 short block home to begin tearing it down to replace the stock 350 in my '69 cutlass. This will be my first engine build and swap, getting real excited! I need your help on figuring out the correct places to attach the chain for a lift. I've heard of using the accessory and bellhousing holes as well as head bolt holes diagonally on the deck.
I'll most likely be buying an engine stand and lift from harbor freight and 3/8" chain. Since the engine is 45 minutes away sitting on a broken wooden pallet, I'd like to know the appropriate bolt sizes depending on the attachment location. Thanks!
BondAR is offline
Old September 15th, 2018, 11:26 AM
Most of the bolt holes have 3/8x16 threads. Those include the bellhousing, cylinder head bolts holes, etc. if your using a carb lifting plate they will be 5/16x18 thread.
matt69olds is online now
Old September 15th, 2018, 01:58 PM
cherokeepeople's Avatar
he said short block so no heads,so the head bolt holes are not 3/8th more like 7/16 or 1/2 don't remember right off hand.
cherokeepeople is offline
Old September 15th, 2018, 02:08 PM
BondAR's Avatar
Thanks guys, I don't know why i didn't check ARP's site for head bolt thread sizes earlier but looks like they list the early blocks using the 1/2" thread vs 7/16 for others. The 455 I'm picking up was from a '74 or '75 delta 88. I'll probably pick up several in both sizes and different lengths and a stack of washers from the hardware store.
BondAR is offline
Old September 15th, 2018, 03:06 PM
All 455s (and all 1964-1976 Olds V8s) use 7/16" head bolts. The switch to 1/2" head bolts happened with the 1977 model year and the switch to windowed main webs.
joe_padavano is offline
Old September 16th, 2018, 04:55 PM
71 & 72,now I want a 68
w-30dreamin's Avatar
When you buy an engine stand,do yourself a favor and buy one with 4 wheels. The engine is much more stable on a stand with 4 wheels verses 3 wheels.
Especially once the extra weight of the heads and accessories are bolted on.
The 3 wheeled stands do work but can tip somewhat easily.
w-30dreamin is offline
Old September 16th, 2018, 05:49 PM
Great big steaming piles of horse excrement! I missed the short block comment. Oops
Old September 16th, 2018, 07:05 PM
BondAR's Avatar
Brought it home! Ended up using inch long 7/16-14 Grade 8 bolts and washers with the load leveler from harbor freight and their crane. Worked like a charm. Thanks for helping!
BondAR is offline
cdrod
May 12th, 2017 07:19 AM
5998DownUnder
December 29th, 2013 02:51 PM
Sampson
December 18th, 2013 07:18 AM
Stevec
October 28th, 2010 05:47 PM
RaymondTx
April 15th, 2008 09:49 AM
Quick Reply: Need advice on lifting assembled 455 short block
