name this relay
name this relay
can someone please view the attached photo and note the 2 prong relay mounted on the firewall behind the vacuum booster (removed). The red wire on the left prong goes to the horn relay on the fender. Please confirm if this is a viable source for 12 volts to get power to the HEI distributor. Thank You.
i will name that relay Charlie
. i am not sure if this is a "switched" 12v source. that relay on my 70 442 is for the convertible top switch and mine is a breaker if i remember correctly? i think its constant hot.
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
