My nearly new Challenger GT
#83
Now that used car prices have seemed to come back to reality, my wife and I are looking forward to a 2 door car.
We have driven boring “practical” 4 door cars for about 20 years. Now that we are almost empty nesters, I might finally get the Challenger I have wanted since they first came out.
As soon as our contract is settled in September, we are car shopping. The idea of a car payment while walking a picket line doesn’t appeal to me in the least!!
#84
Out of Line, Everytime😉
First the good, I got over 40 mpg Imperial last 4 hour trip. It was 41.7 at best average. I think everything is at the break in sweet spot, just under 127,000 km. The bad, I hooked up my boat to drive 2 hours away to go fishing. Problem is, I didn't get the hitch on the ball completely. It came off and looked like it only damaged the trailer spare, a half used up tire and scuffed the top of the bumper. It looked fairly deep. Great, it will need fixed. So I cleaned it off with brake cleaner and there was one tiny spot down to black, touched it up. I then polished it. It can only be seen in just the right light. Talk about lucky. We got on the water, the depth finder arm broke but I didn't let it get me down. We also caught 50+ fish, so worth the struggle.
#85
Glad to see you are enjoying your car. I cannot hate on these cars at all. Can be plenty of squirrels driving them sometimes but can't hate the cars.
#86
They are great driving cars and actually look good, something severely lacking on new cars. Also these aren't the old Dodge's with half *** engineering and quality. I know, we owned and currently own an older Dodge. This one is even a big improvement over the 2010 we had.
#87
I really like this Spectre cold air intake, a noticeable gain IMHO. I have achieved my best MPG, 41.7 Imperial since running this intake. I am guessing 1 mpg to 4 mpg, depending on driving habits, unless my display is lying. My Hellcat lower box got lost in the mail, not bothering to get another one. I will be putting in the headlight plugs and stock box in for the Winter. I have the silicone adapter from the Spectre tubing to the stock box. Since sanding the edge of the tube, the filter hasn't come off. I wanted to put in the biggest filter possible and this Amazon dry flow filter fit, perfect fit and matches the car.
#88
Well I am now at 131,000+ km. I picked up the higher end brake pads, got a bunch of dollars on my CT card. I may pick up a spare Continental serpentine belt. My last Challenger needed pads at 150,000 km. I will access when I install the studded Winter tires. I also picked up this off Ebay. I may do minor cleanup on the casting lines before installing depending on how it looks. It is the Performance Upgrade intake, better flowing vs my stock intake.
5281803AA Intake Manifold Assembly Replacement for 2016-2022 Jeep Grand Cherokee Dodge Durango Chrysler Pacifica 3.6L Koomaha
#89
It arrived, looks good, not bad for just over $125 CAD. The only other parts I might consider are the 8 hole injectors, slightly better MPG, NGK Ruthenium spark plugs and Accel coils. I got the Autolite Iridium spark plugs really cheap a while back, I may change them alone if nothing else fails in the next few thousand miles. I'm sure the original plugs should be changed soon, 150,000 mile is the suggested, I may be an easy one later today.
#90
Well I decided to do the spark plugs, got the Autolite Iridium spark plugs really cheap off Amazon a year or so ago. There was .010" worth of wear, definitely time. With the upper intake off, I could finally finish sucking out the mouse nest with the shop vac. Pretty sure it was from when this car sat on the dealer lot for a year. I tossed the 1/2 chewed pad under the upper intake. I used a shot of dielectric grease in each coil boot and a small amount of Permatex Cooper Antiseize on each plug thread. I used the piece hose to hand thread each spark plug. Everything torqued to factory specs including the spark plugs and gapped at .043". I just put in the head light plugs for the Winter and removed the mudflap I completely blocked off the coolant overflow from the air filter. Car runs great after the test drive. I also polished it with Tutle Wax and Meguirs Ceramic polish, both work on plastic.
#91
A guy rolled up in chevy truck on Friday night at the stop light and asked if I wish I had a chevy. I said nope and he then said what a nice car it was. He asked if it had the Hemi, I said no. I told him AWD and I even tow my boat. He said AWD, wow and what a nice car it was again.
#92
Looks great after your wax and ceramic job.
Thanks for the reminder on the periodic maintenance and the helpful notes on plug replacement. My plug replacement schedule is 100,000 miles--I'll be there next year. Manual transmission and rear axle fluid changes are at that mileage point as well.
Your maintenance reminds us that winter's coming. And I hope it hurries. The summer has been dry and unseasonably warm here. Today was cooler, 37 °C with dew point of 20 °C. It's currently raining, however.
Hard to believe. I love my 2010--but then I haven't driven newer ones to give me a point of reference. And after putting thousands of dollars into "improvements" it can be hard to give up a favorite car.
#93
Yeah, I did the transmission service with an aluminum pan to replace the plastic one. I did both diffs and the transfer case, all about 30,000 km ago. I will check the brakes when I put on the Winter tires next month. Winter is something we never hurry here, it has been warm, no major frost yet. Probably because we get half the year of cold and snow here. My 2010 wasn't a bad car besides the 3.5 V6, this one has been exceptional is all.
#94
I went with Rustoleum Florescent Green then Tremclad(Rustoleum) Clear. It is pretty close to Go Green. I sanded it and hit it with brake cleaner first. I removed over spay where it got past the tape with carb cleaner added decals and then Clear coated it. I have got the decorative Challenger door sills.
#96
Here is the engine cover installed.
I also decided to buy the best tires on the market. Continental Extreme Contact DWS06+ in the P235/55R19 105XL W speed rating.
Of course we just got 6 inches of snow, roads were almost dry but will be 10 above freezing by the end of the week. Hopefully they are as good as everyone say they are. On sale, all 4 are over $1500 installed! There is a $70 mail in rebate, so just under $1500 Canadian.
#97
I did an early oil change on my GT due to my upcoming work schedule. I ordered some 0W20 Vavoline 0W20 Restore and Protect from Ebay, not available in Canada yet for some reason. I received an oil covered box and a 1/2 a jug. You can tell it is a different oil, has a strong smell compared to their Advanced Protection 0W20, which Canadian Tire had a good price to complete the oil change with a Purolator Pure One cartridge filter. I decided to do a tire rotation at 8000 km, rear brakes still have plenty of pad at 145,700 Km. I did the front brakes a bit early, good considering I tow with the car. I moved back the heat shield to look at driveshaft center bearing, a common failure point, well it failed. I lubed the center bearing and soaked the exhaust bad clamps, bolts and mount bearing mount bolts. I wasn't paying $500 CAD for the ultimate upgrade housing and bushing. So I looked on Amazon and found a two piece housing with a two piece bushing for under $80 CAD with very good reviews. I just did my Daughter's Edge, it sucked removing the old bearing and separating the driveshaft. The reviews showed cutting the old housing and burning off the rubber to reuse the old bearing, which I plan on. Supposedly it can be done with exhaust on, we will see.
#98
The bearing holder is well made and the one lower review was how hard it was for him to change. I'm not paying 5 times the price for basically the same part with a couple of extra pieces and no doubt still made in China. There is another more reviewed and higher rated for $10 more and is the same part. The Challenger is on 4 jack stands on the suspension arms in front and spots beside the arms on rear. Yeah, the exhaust had to come down. Cut the old holder in two places. The bearing was basically skinned, spins fine, lubed it up good and trimmed the one edge with an exacto knife. It is in, orange hybrid loctite on the allen head bolts and mount bolts torqued to 22 ft-lbs. Just need to finish putting the exhaust in place, easy peasy.
#99
Well, the Challenger is starting to show some wear and tear. I see one stitch on the outside edge of the drivers seat has let go and the 8.4 touch screen is starting to deamination on top. One is an easy fix, the other not so much.
#100
#101
Yes, for sure. It sounds like there is a cheap fix for the screen, only minor so far,soan live with it. I am also around 155,000 km. After a quick seat repair, four 235/60R18 studded Winter tires to replace the aged out set on the Koni aluminum rims. Adding sensors this time as well.
oldcutlass
September 17th, 2017 05:50 AM
