Muncie 4 speed
Muncie 4 speed
Hi all,
I recently purchased a 1969 GTO which I thought was all numbers matching, turns out the Muncie 4 speed has a stamping of P8C07 so March 07, 1968 and a VIN of 38M307433. I believe this is an Olds transmission from a 1968 car assembled in Lansing, MI. If by a remote chance it matches someone's VIN or at least year and build date I would be happy to reunite it. I would only want a 1969 Baltimore built or non stamped replacement case transmission in return. I know it's a longshot but posting just in case, it will probably be available until October 2021.
Hi all,
Is it an M20 or M21? I think I have a 69 Pontiac M20 in my car. I'll try to get the VIN derivative tonight
edit: mine is a 67... P7C22 with no VIN stamp which would have been correct for 67
That's an early build tranny by the VIN. I don't understand why the date stamp is so late. My VIN is M352110 and it's a late April build. Maybe check to make sure it's a zero....
![](https://cimg2.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/38e05571_91d6_43df_85fe_9a01972fed38_2d1565b8a7310c5d2e54293fc2d056b7a2039bae.jpeg)
Build date I also have the shifter with linkage, only missing the handle and ****
![](https://cimg9.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/6ed94381_4ac0_41f5_9e4d_6090ef9f7867_f7db5df03c7975bbbd852fc0da92500b34d5d1f7.jpeg)
VIN stamp
OK that makes sense. I was thinking just the A-Bodies started with 3. I didn't realize that the A,B,& C's started at 000001
fast67vellen2o
December 28th, 2010 11:32 AM
