Motor Mounts for Omega Engine swap is Sat.
Old Oct 20, 2013 | 04:34 PM
QS442's Avatar
Motor is going in next weekend. I have found some 403 firebird motor mounts (frame) but they are different than what was relayed to me on forum. Can i use either or? or do I need the purchase the brackets?
The motor that is going in is a Olds 350 and it has motor mounts on the block already. The motor was just pulled from a 67 Cutlass. Can I use the mounts on the block or do I need 403 specific mounts?
Here are pics of the frame mounts that are in the firebird.
Also are the pic that were relayed to me on forum. Which ones?
Old Oct 20, 2013 | 04:36 PM
2blu442's Avatar
The pictures didn't come through.
John
Old Oct 20, 2013 | 04:37 PM
QS442's Avatar
Here are the 403 trans am motor mounts on frame. Can I just use these mounts to bolt to my Omega and will the motor mounts(block) fit onto the 403 mounts (frame)?
Old Oct 20, 2013 | 04:38 PM
svnt442's Avatar
You need to use the T/A brackets like these:
Old Oct 20, 2013 | 04:41 PM
QS442's Avatar
Ok. Those are like these.
Old Oct 20, 2013 | 04:43 PM
QS442's Avatar
Am I able to use the mounts that are on the olds 350 block already? They will sit right on the brackets?
Old Oct 20, 2013 | 04:44 PM
QS442's Avatar
SVNT442. Are those for sale?
Old Oct 20, 2013 | 04:46 PM
svnt442's Avatar
OK...the ones you have on the frame STAY PUT. These bolt to the block and they are not mine. I just pulled a pic off the web and it happened to be an ended Ebay auction.
Old Oct 20, 2013 | 04:58 PM
svnt442's Avatar
And these frame mounts.
Old Oct 21, 2013 | 07:31 AM
If they are the normal rubber Olds motor mounts, no. You either need the correct metal frame mounts to use with the rubber motor mounts, or the rubber clamshell frame mounts from the T/A and the matching metal engine brackets.
Old Nov 12, 2013 | 05:30 AM
QS442's Avatar
Mounts not lined up?!
Ran into a big issue with the swap. The metal brackets for block fit perfectly. The motor mounts for frame fit perfectly on the frame. All the passenger side mounts lined up perfectly and were able to be bolted together. However, the drivers side is off about an inch.
Old Nov 12, 2013 | 06:54 AM
66400's Avatar
Complete motor mount system from any 76-79 Cadillac Seville will work. All these cars had 350 Olds gas or diesel engines with the X body sub frame.
Henry
joesw31
May 31, 2015 04:17 PM
Nasty455
Mar 20, 2012 04:57 PM
78 omega 468
Nov 19, 2011 10:03 PM
Ice
Jun 13, 2009 06:11 PM
flatoz
Mar 15, 2009 02:03 PM
