motor mounts to lower engine?
Old Oct 26, 2022 | 06:15 AM
user 83737473's Avatar
Just wondering if motor mounts differ from manufacture to manufacture as far as how high the motor sits? and is there a way to know. The reason for asking is I'm looking to lower motor 1/2" to make a little more room under hood.
Old Oct 26, 2022 | 07:48 AM
The motor is as low as it can go with the stock mounts. The oil pan to crossmember clearance is the limiting factor.
Old Oct 26, 2022 | 09:11 AM
Thanks Joe, I was not thinking about that. I was thinking of possible pinion angle change issues. I currently have 3/16" clearance but looking for a little more without major modifications. Even if I could get 1/4" more would be nice. I'll figure something out.
Old Oct 26, 2022 | 09:13 AM
The easiest thing would be to slot the holes in the motor mounts where they bolt to the block.
Old Oct 26, 2022 | 09:40 AM
Great idea! Thanks!
Old Oct 26, 2022 | 10:25 PM
I wonder if it's worth welding the old holes up once happy.
Old Oct 27, 2022 | 05:46 AM
At the risk heat damaging the rubber, probably not.
JLawrence
Feb 17, 2020 05:07 AM
EsoWuhn
Feb 11, 2020 06:04 PM
1971raresx
Aug 18, 2016 08:22 AM
csouth
Apr 10, 2012 02:19 PM
gabe442
Non-Olds Engines
Dec 1, 2011 11:19 AM
