Moser Muscle PAK and Value
Old Aug 23, 2024 | 04:38 PM
jonnyslim63's Avatar
Hi,
I have a 1968 Numbers Matching convertible with color code Y1. I painted it Tweety Yellow and Put a new black top on it. The gear set is not original as I had to have it serviced and it turns out it is a malibu gearset. Anyway, is it a bad idea to put a MOSER muscle PAK with some highway gears in it ? I was thinking that it would add value. It's not all original anyway, as I took the advice from here from long ago "paint it the way you want it, enjoy it, and if the buyer wants it original, let them go that route". Anyway with all that said, it would be nice to have posi and still keep the gear ratio because the car gets damn good "Smiles to the Mile" the way the gearing is now. It's not the original gear set. The ratio is, but the gears not, according to the shoppe that serviced the rear end. Any thoughts on this. It's about a 6k investment... Ha Ha... it's about a 6K addition to my heirs saving account I should say. Please ask me to clarify. I am typing one handed and it is arduous. Recovering from Shoulder surgery. Attaching some pictures for fun.
thanks all in advance.
Jon
in progress
Fun Ad
July sometime 2024 oldtown Pittsburg CA
Old Sep 5, 2024 | 05:22 AM
Moser is obviously a well-respected name in rear axles. As for the actual ratio you select, it depends on how the whole car is set up and how you plan to use it. Personally I'm not a fan of highway gears for a musclecar. These engines were designed to run all day long at 70 MPH with mid-3-series gear ratios. People who are used to modern cars with OD for gas mileage aren't used to that.
Old Sep 5, 2024 | 10:13 PM
What is the current ratio?
Old Sep 5, 2024 | 10:44 PM
70W-32's Avatar
Why do you feel you need to install a $6000 rear end, when you can add posi, or posi and a gear, for 1/4 of that.
Old Sep 6, 2024 | 06:21 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Taking a quick look at the Moser Muscle Pak 12 bolt. Ouch, as said 5K with any sort of options and then shipping. The tallest gear available is a 3.08 ratio, middle of the range for factory gear ratios. What gears are in it now?
Dave442
Jun 4, 2024 10:49 PM
stevengerard
Drivetrain/Differentials
Jan 17, 2018 03:24 PM
78Cutlass4Speed
Aug 1, 2017 03:17 PM
Joeg
Oct 27, 2014 01:47 PM
John McGraw
Oct 3, 2009 12:17 PM
