modern features from junkyard parts
Old Jan 17, 2015 | 08:10 PM
DewChugr's Avatar
Photoshop God
Not sure if this has been discussed.
Got power locks and want keyless entry cheap? Some lat 90's cars have a self contained RKE (remote keyless entry) module. You program the fobs by grounding a wire on the module. I found one on a 00 buick for 2 or 3 bucks. It was a royal pain to get out on this car because there is a bolt from above that's nearly impossible to get to. They are supposed to be available on late 90s Monte Carlos, some Buicks, Pontiac and Olds. Features include unlock one for driver door, twice for all doors and trunk release. I think it will flash your parking lights if you want also. With some creativity you could use one of these to do other things as well. More here.
Have power windows and want one touch down on all of your windows? Ford Taurus from at least 92-95 use a module separate from the switch to do the one touch. It's behind the driver door panel. If you add this to your passenger door that window will be one touch from the passenger side as well as the driver side. Add them to rear doors if you want. More here
Old Jan 18, 2015 | 06:43 AM
RetroRanger's Avatar
72 Olds CS
Cool ideas thanks for posting....I would like to find some 3 point seat belts from a newer car that fit and work well in our older cars
Old Jan 18, 2015 | 03:56 PM
jpc647's Avatar
Cool, thanks for the ideas!
Old Jan 18, 2015 | 04:11 PM
Macadoo's Avatar
X2 on that.
Old Jan 18, 2015 | 05:19 PM
Octania's Avatar
x2
Stand-alone systems to modernize or modify the older cars.
Old Jan 19, 2015 | 12:42 AM
rustyroger's Avatar
'87 Delta 88 Royale
Great idea, how about a sticky for what can be done?.
Roger.
Old Jan 19, 2015 | 07:50 AM
DewChugr's Avatar
Photoshop God
Roger.
Only other idea I have right now is auto dimming mirror with compass and map lights. I'm pretty sure that has been discussed before. Look at Lincolns, Caddys and Sebrings.
I'll be on the lookout for door lock solenoids and trunk releases that will fit my 71.
Alocatelli
Aug 4, 2016 05:55 AM
Shelley
Aug 21, 2012 11:00 PM
w-31cutlass
Aug 4, 2011 06:19 AM
Omicron
May 10, 2010 05:43 AM
squirell
Nov 8, 2009 04:38 PM
