Misplaced logic?
Old Sep 13, 2024 | 07:36 PM
72455's Avatar
1972 U code Supreme
Misplaced logic?
If you're drawing 15 inches of vacuum through a line that is 5/16" in diameter and 2 ft in length and you change the line diameter to 1/8" that is 4 ft in length, does that affect anything?
Seems to me the smaller diameter would be more restrictive, thus changing the dynamics of the system, or is my logic misplaced?
Old Sep 13, 2024 | 09:30 PM
Depends on the load, but, overall, it would pull vacuum to steady state condition more slowly in the second example. If it were filling a vacuum can, you might not notice a difference, all depending on how often that can is tapped.
Old Sep 14, 2024 | 06:29 AM
If you are talking about your trans vacuum modulator line, there is no difference in functionality. At some point the combination of length and diameter may induce temporary differences in the pressure level from one end to another, but that is a transitory event. The reaction time of the modulator won't be affected by it.
Old Sep 14, 2024 | 08:27 AM
You’re correct when it’s flow rate, but the distal end of the hose is blocked so there’s no air flow after the initial vacuum application.
Old Sep 14, 2024 | 09:31 AM
72455's Avatar
1972 U code Supreme
So I've noticed...drove it to work today and all good. Thanks Joe.
Puppy boy
Sep 20, 2021 05:32 AM
cfair
Nov 19, 2017 05:03 PM
69ho aurora
Hurst/Olds
Mar 26, 2013 07:55 PM
Johnny Cage
Aug 7, 2012 07:39 AM
Homestar
Apr 3, 2011 05:54 PM
