mirrors
Old Jul 10, 2015 | 10:52 PM
dullahdee's Avatar
Red face mirrors
Hi guys, I purchased my 67olds cutlass supreme 330 in Texas and shipped it back to New Zealand, I now live in Perth Australia ,we took the cutlass for a registration and although we drive on the lefthand side of the road and it is a lefthand drive they still require me to have a mirror on the rightside door.Any idea which mirrors I could use or where I can order it from and also I have 20inch wheels on the car and it rubs on the inner guard on full lock does anyone know what I can use or install to restrict the full lock.
Old Jul 11, 2015 | 04:37 AM
svnt442's Avatar
I would put the correct size wheels and tires on it. You don't want to try and restrict the turning radius of the car.
As far as the mirror goes, I don't know of any that would match the factory mirror on the left side of the car.
Old Jul 11, 2015 | 06:50 AM
A passenger side mirror was a factory option for 1967. Fusick used to sell repros, but I don't know if they still do.
The WHEEL diameter isn't the problem. It's the TIRE diameter, TIRE width, and WHEEL offset that will affect the clearance. Restricting the turning radius is not a great idea, which is why there is no easy way to do it.
Old Jul 11, 2015 | 08:32 AM
svnt442's Avatar
I know that Joe, but with a 20" wheel he's looking at something with a sidewall of less than 2" to make it even close to factory diameter and who even knows what the width and offset is. A tire like that won't last long in day to day driving especially if the roads are suspect.
I was unaware about the mirror.
Old Jul 11, 2015 | 09:25 AM
I'm no fan of big wheels and "rubber band" tires, but that's the OP's call. 225/35-20s are readily available and about the same diameter as the original tires. With near zero offset on the wheels, they should not rub on the front. 245/30-20s are also readily available and the same diameter, but a little wider They SHOULD clear, but I can't say for sure. The question remains, what is the OFFSET of the wheels on the car?
Old Jul 12, 2015 | 06:21 PM
Ozzie's Avatar
Fusick does show the outside manual mirror for 1967 (SM6768L @ US$79.50 + shipping)(left only). It could probably be used on the right door if the checker would approve. In 1967 Oldsmobile did offer a remote control mirror as an option (D33 @ $9.48). The manual mirror was standard equipment. If perfect condition is not required, the salvage yards sell both the manual & remote control mirrors for the 1967 at about $25-55.
Old Jul 13, 2015 | 07:16 AM
The contour of the bases are mirror image from LH to RH to match the top of the door. The LH mirror does not sit properly on the RH door. Call Fusick and ask if they have any of the passenger side 67 mirror repros still available.
Old Jul 13, 2015 | 07:50 AM
Mine has a right hand mirror, and it is aftermarket I think because it's kind of close. I may go for a set of Fusick ones.
I have been told it was only a dealer option and not a factory part.
Old Jul 13, 2015 | 09:28 PM
Ozzie's Avatar
Thanks for catching that, Joe. Fusick's photo made it look like it might interchange as some Olds mirrors did, but apparently not in this case. I suppose that's why it says "left only". A really long distance call (or e-mail?) will be in order.
Old Jul 14, 2015 | 05:53 AM
lemoldsnut's Avatar
None of the factory manuals I have show a factory right mirror for a 67. If you use a factory left mirror on the right it does not give you a good view as Joe said it is set up for the left. If there is a different mirror like Fusick used to sell I would love to get a few for the 67's we have.
Old Jul 14, 2015 | 07:59 AM
From the factory parts book:
Group 10.185 ― MIRROR, OUTSIDE REAR VIEW - MANUAL TYPE
230365
1967 ALL - RIGHT
Old Jul 14, 2015 | 09:27 AM
Octania's Avatar
I reckon if you really had to, one could re-shape the base curvature to suit your application. It might not be super pretty underside when done, depending on your skill set, but it would work. Unless the angle is extremely far off, like 70-72 chrome mirrors.
There is always the generic JC Whitney one-fits-all type. Won't match but will satisfy the inspectigator.
StickW31
Jun 3, 2011 08:24 AM
SBONinetyEight
Ninety-Eight
Dec 1, 2006 11:28 AM
Chumley
Nov 6, 2006 01:49 PM
Super88inWilm
Mar 30, 2006 04:32 AM
