Mild rebuild/performance 403 olds
Old Oct 22, 2021 | 08:38 AM
stxbuck's Avatar
Hi guys, new member here. Just wanted to say I have learned a great deal from many of you guys here. But I need some help. I have recently purchased a 79 T/A with a 403 olds. I want to keep the car as stock as possible. But with the limited HP I wanted to give my old olds 403 some power. Nothing fancy, streetcar with a little juice. I was thinking about changing the steel intake manifold to an aluminum one, maybe some headers, a good exhaust system, a mild cam. What do you guys think? I already searched the forums and threads but all I read on is some major mods for high HP. ANy help is appreciated or if anyone can point me in the right direction. Thanks.
Old Oct 22, 2021 | 10:43 AM
70W-32's Avatar
What is your re axle ratio. Most T/As had mid to high 2.xx If you change to a 3.23 to 3.42 ratio the car will be completely different without you having to tear into the engine,
Keep in mind that a intake manifold change may affect how the shaker fits.
Old Oct 22, 2021 | 11:37 AM
stxbuck's Avatar
The sheet reads GU1 241 Ratio Axl
and G80 posi axle
Old Oct 22, 2021 | 12:26 PM
Ugh, I thought my car was bad with a 2.56 rear, but 2.41 must really suck.
As said, swap that to something in the mid-3 range and it will feel as if you have a lot more horsepower. I did that in my old 70 Supreme, going form 2.56 to 3.08 felt like I added 50 hp, then again swapping from 3.08 to 3.55 felt like another power increase. Do a gear swap and you won't be disappointed. The rear gears will already be there to complement any engine mods you may do in the future.
Old Oct 22, 2021 | 04:03 PM
fleming442's Avatar
Rear gears for sure. You'll lose some top end, but be realistic; how often do you do that, anyway?
Engine wise, intake and a manifold back 2.5" dual exhaust will be more than you need with bolt on mods. Keep in mind that it's only 7.9:1 compression, so most things like headers and a cam are futile. Do some thin Cometic head gaskets before all that..
Your local emissions regulations make a big factor to consider.
Old Oct 22, 2021 | 07:13 PM
Put 3.73 gears in the rear end, swap in a 200R4. If that’s not enough, a little exhaust work would be a improvement
Old Oct 23, 2021 | 12:12 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
We have a winner. The stock 4A heads are terrible on the exhaust side. Early 350 heads will raise compression a point, you need a A4 or Performer on a Trans Am to work with the shaker. Then a cam swap on top of the rest will make it a fun car.
Old Oct 23, 2021 | 07:56 AM
BackInTheGame's Avatar
You guys are making me miss my '79 T/A..
Old Oct 23, 2021 | 09:04 AM
Both points are excellent; that engine has to have the turd fixed before you polish it, which is that it's late 70s emissions style setup, so, compression.
Old Oct 23, 2021 | 09:18 AM
GEARMAN69's Avatar
3.08's would be a awesome upgrade and still driveable on highway. Headers for sure. a set of 68-72 350 heads 5, 6 , 7 , 7a with bigger valves like 2.07/1.62 combo (open up heads bolt holes to match 403 if using the early heads) , a mild cam ... honestly a generic @ 050 rated 214/224 112 is plenty and work in the rpm range this head swap on stock dish pistons gets you up to 9.5:1 ish ad needs 93 octane.. A simple regular Edelbrock Performer .. If you don't change heads go with a different cam for the low CR with a tighter 108 or 110 lsa just regardless intake side at least 210 @050 but not more than say 220 degrees
Lost of opinions and options here. on a stone stock engine I wouldnt go all the way to 3.42 gears from 2.41 , 3.23 overall best IMO max
One of the guys I race with is a original owner of a 403 car he bought new and that original engine with some marine cam swap with 3.23's but still low compression 7.9 ended up in the low 13's in 1/4 on slicks, now its 12s with a Pontiac engine but still very good results for low CR 403
Old Oct 24, 2021 | 05:32 AM
stxbuck's Avatar
in my research I've read about the horrible compression. But where I am parts are non existent and there are hardly any master mechanics that know how to deal with the older engines.
Old Oct 24, 2021 | 06:00 AM
fleming442's Avatar
I've read and reread this several times. You don't have to be a "master" mechanic. You're dealing with basic engine principles: suck, squeeze, bang, blow.
Or, are you saying that the mechanics around you don't know anything beyond a code reader and Google?
Old Oct 24, 2021 | 09:49 AM
Wait till the new small chamber Edelbrock heads come out. Dual exhaust, maybe headers and a cam swap will be all you need otherwise. Mark is trying to convince them to do them so a regular Performer intake can be used without welding.
Old Oct 24, 2021 | 11:50 AM
I agree, you don’t need a master mechanic to swap heads or install a camshaft. I did that stuff when I was in high school. Just remove parts then reverse the process to install the new ones.
Old Oct 25, 2021 | 10:25 AM
cutlassefi's Avatar
Keep in mind that an intake manifold change may affect how the shaker fits.
^^^^^^ plus you have less than 8.0:1 compression in stock form so a cam change would be like putting lipstick on a pig, waste of time and money.
Thanks.
Old Oct 26, 2021 | 01:55 PM
CANADIANOLDS's Avatar
To wake it up a gear swap is the easiest and least expensive. gears for the 8.5” are cheap new or used. Go 3:08 minimum
A cam swap is also a good idea. You need a low rpm TQ type cam with short advertised duration with good lift. You have a few choices that will work with the stock heads as is.
best ones are;
Comp XE250H
Comp 250H
Lunati 60800LK
add headers if want but these will work well with stock exhaust manifolds
always rejet the carb..those are notoriously lean
Old Oct 26, 2021 | 05:49 PM
The idle circuits are probably the main issue on these late 70's carbs, especially if the compression and cam are increased and headers installed. Cliff has a nice custom 44 primary rod for these. Tune with a wideband to get it bang on.
bigdooly
Nov 15, 2018 05:32 AM
Copper Nine Eight
Jul 4, 2017 10:05 AM
Cjs1969
Nov 18, 2012 05:29 AM
79nova4door
Jun 17, 2011 02:22 PM
kenny
Oct 1, 2009 04:58 PM
