Lower radiator hose with spring
Old Aug 16, 2022 | 08:49 PM
WildHareRacing1970$'s Avatar
Question Lower radiator hose with spring
Trying to find lower radiator hose with spring. Seems like everyone has a stock one just not one with the spring! Anybody have a guy? I have a 70 Cutlass S with a 455. Thanks
Old Aug 16, 2022 | 09:09 PM
gs72's Avatar
72Cutlass S
Inlinetube.com sells the spring. You can put it in any hose you buy.
Old Aug 17, 2022 | 12:56 AM
fleming442's Avatar
Springs are plentiful in junkyards.
Old Aug 17, 2022 | 10:43 AM
69 Hurst's Avatar
Olds Fanatic
Just bought one a couple of weeks ago. You will have to enlarge the coils as their spring is too narrow and will eventually make its way up into the water pump or radiator. All I did was "unwind" the coils and it made the spring fit snug.
Old Aug 17, 2022 | 01:50 PM
Oldsguy's Avatar
Past Administrator
Well I wish I was near you then. I have been looking around junkyards for parts for my '72 and haven't found anything near that old. The closest was a '75 Chevy sedan all beat to hell. Most yards I visited didn't invest in anything older that 20 years old. One guy I called asking for old GM parts (being really general in my request) replied that he had some "really old" 90's Chevy pickups.
Old Aug 17, 2022 | 02:02 PM
You can find springs on Ebay and you can also make your own. The newer hoses seem to be stronger which in my opinion do not warrant the use of a spring, I can't remember the last time I've had a lower hose collapse.
Old Aug 17, 2022 | 02:11 PM
I made one for my Chevy approx 10 years ago and just pulled the hoses for R&R, I will get a picture of it. Wound solid wire around a broom handle, iirc.
Old Aug 18, 2022 | 06:08 AM
69 Hurst's Avatar
Olds Fanatic
.....I can't remember the last time I've had a lower hose collapse.
Happened to me on a two year old hose from Fusick.
Old Aug 18, 2022 | 06:19 AM
tnswt's Avatar
'70 4-Speed W Machine
A collapsed radiator hose can be caused by a faulty vacuum release device in the radiator cap--test the cap.
Old Aug 18, 2022 | 08:07 PM
Dunno how a hose collapses when the system is pressurized to 15 psi.
Old Aug 18, 2022 | 08:47 PM
redoldsman's Avatar
Proud Viet Nam Veteran
That doesn't surprise me.
Old Aug 19, 2022 | 05:27 AM
tnswt's Avatar
Indeed, a lower hose collapse most likely results from a weak hose, or some sort of obstruction in the system, for example a partially stopped up radiator, rather than something similar to negative pressure as I stated in post #9. In this case, the water pump would pump more water than that available in the lower part of the radiator causing collapse; some argue the spring is unnecessary in the lower hose in a properly functioning system.
4-Speed
Jun 13, 2019 02:47 PM
Stevec
May 25, 2015 05:00 PM
70cutty
Feb 10, 2014 06:41 PM
Aron Nance
Oct 14, 2013 07:45 PM
radioburningchrome
Oct 7, 2009 05:11 PM
