lookling at a 455
Old Nov 17, 2013 | 08:50 AM
Kyle's 77 Cutlass's Avatar
lookling at a 455
Hey guys and gals. Many of you can help me. I am not a much fan of a big block,like my sbo but I wouldn't mind a 455 or a 442 engine if I could find on by fluke. What are the casting numbers of the block and head letters I should watch for. I have looked at other pages but I just get lost. Thanks
Old Nov 17, 2013 | 09:15 AM
oldstata's Avatar
Justin
Any Bbo is a good builder depends on condition and plans ?
Heads really depends on what you want out of it I would pass on J heads unless they were on the block for a good price. Any other heads are okay. Keep in mind if rebuilding a set of heads if you start to reach 800+ you can get pro comp heads for around 1k must likely a few more bucks for brackets and rockers ect
I would look between 67-70 Bbo so you can have higher compression motors if not planning to rebuild
Old Nov 17, 2013 | 09:29 AM
So a couple of hundred for an engine is a fair price?
Old Nov 17, 2013 | 09:42 AM
oldstata's Avatar
Justin
Carb -oil pan is a great deal see if it turns over freely
455? Or 400
I got two 455 with th400 attached one I paid 500 for but is locked up the other I paid 200
Old Nov 17, 2013 | 10:24 AM
Okay. I was looking online and they say if you can find a tornado 455,this is the cream of 455's.442 455 and the tornado 455 are the same. True?
Old Nov 17, 2013 | 10:27 AM
oldstata's Avatar
Justin
From my understanding 68 toro 455 stock is the best.
I think the 442 just had big valve heads and 71 up have low compression so if you can find a pre 70 ready to run go for it, but if you plan to rebuild any cheap core is good
Just my 2 cents
Old Nov 17, 2013 | 10:39 AM
Thanks very much for your help
Old Nov 17, 2013 | 10:46 AM
Octania's Avatar
200 is practically scrap metal price.
All the bits and pieces add up, and are no longer just a quick boneyard run away for most of us.
200 would be cheap for an engine with an unusable block, but good
Carb 7028251 or better
Intake
Heads other than A or J
oil pan and all the covers
oil filter adapter
crank, balancer, flexplate, set of rods
air cleaner
Distributor HEI era or wildly rare number points type
BB exhaust manifolds like W-Z pair or at least one.
Old Nov 17, 2013 | 11:18 AM
Intake
oil filter adapter
air cleaner
So the parts you mentioned would add up to ?
Old Nov 17, 2013 | 11:20 AM
so 200 is a steal then I take it. Does it matter what year?
Old Nov 17, 2013 | 04:06 PM
Olds_71_442's Avatar
Yeah.....$200 is a very good deal. I've seen guys want that much for one that is seized.
The higher the year, the lower the compression. The highest would be around 69 or 70. Also, you'll find more raw performance if the engine comes from a 442 than if it came from a big car like the Olds 98.
Old Nov 18, 2013 | 06:21 AM
Okay. Thanks
dp442
Feb 15, 2011 04:22 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
egknz
Jul 21, 2009 01:09 PM
