Longer wheel studs
Old Feb 2, 2016 | 07:05 AM
oregontopcat's Avatar
Longer wheel studs
The 70 442 almost ready for paint so I was getting ready to install the aluminum wheels which I want to use but I discovered that the studs are not long enough to go through the wheel and leave enough threads for safe wheel attachment. The question is who makes a longer stud?? I have done a pretty good search but have not come up with anything. Thanks, Dave
Old Feb 2, 2016 | 08:13 AM
Chesrown 67 OAI's Avatar
Pik a nut makes many lengths. Real long racing ones are at Summit. i doubt you want those. I believe you can get 1/2" longer. You must make sure your lugnuts dont bottom out if you are using closed end ones
Old Feb 2, 2016 | 08:26 AM
http://m.advanceautoparts.com/mt/sho...48.1/9210024-P
Heres one that is 1/4" longer than std. Mahe sure when you buy that you get only obe thatchas knurl between .472 and .475. 472 is std . 475 is recommended for replacement so they fit tight
Old Feb 2, 2016 | 10:17 AM
Thanks Chesrown, I will order from them, 1/4" would do it.
Old Feb 2, 2016 | 05:02 PM
oldolds88's Avatar
make sure your wheels don't take the long shank lug nut,before using regular lug nuts. my wheels take these
Amazon.com: McGard 62820 Chrome Duplex Long 1.00" Shank Style Lug Nuts (1/2" - 20 Thread Size) - Set of 8: Automotive Amazon.com: McGard 62820 Chrome Duplex Long 1.00" Shank Style Lug Nuts (1/2" - 20 Thread Size) - Set of 8: Automotive
Old Feb 2, 2016 | 06:41 PM
Thanks Oldolds, I will make sure but mine are 7/16 thread size.
Old Feb 2, 2016 | 07:03 PM
oldolds88's Avatar
check the lug nut area on the wheel,if its not tapered,chances are it needs the long shouldered lug nuts. what wheels are you using? any pics?
Old Feb 2, 2016 | 08:10 PM
The wheels do use a taper on the nut even though they are aluminum. Old school wheels!!
Old Feb 3, 2016 | 03:08 PM
BlackGold's Avatar
Is the taper of the aluminum wheels the same as that of your nuts?
I know someone who lost a big boat on a trailer with aluminum wheels because he used the wrong taper lugnuts.
Old Feb 3, 2016 | 03:31 PM
knock one of your studs out and mic the knurled shank for sure before you buy. I am 99% sure yours will be .472 but theres always a chance that they are the larger .555 ones.
Old Feb 3, 2016 | 04:32 PM
CRUZN 66's Avatar
Olds Fever
If you are using an older style aluminum wheel (such as an ET Wheel), you may need a lug nut with a 60 degree conical seat with shank...
Check this site: http://www.summitracing.com/parts/crr-27802-4/overview/
Old Feb 3, 2016 | 07:39 PM
The wheels use a std taper and no nose, The nuts are the originals and came with the wheels which I have had for almost 15 years. The holes in the wheels will not accept a nose on the nut, just large enough for the studs. Thanks for all the help, found the studs using the doorman pt#.
1964F85
Nov 13, 2019 08:40 PM
joe_padavano
Site Help
May 17, 2014 06:17 AM
cld
May 22, 2013 12:29 PM
70cutlass350
Aug 28, 2012 05:14 AM
chris83
Jun 12, 2009 10:38 PM
