Lifting Options For Working On Your Car...
I have been considering some lifting options for my car(s).
The best option (if there's room) and IMO is a decent rack lift. I'm told they are about $3000 installed. But a little out of my space limitations and I would definitely hear about getting one -forever - from you know who.
But another possibility is the small steel ramps that you see in the auto stores - which give about 8" more of floor to car clearance. The cost is about $100 for a pair. Probably should also buy rear tire blocks to go with this option, for safety sake.
Then there's the hydraulic racing jack option. Using one of these until you place HD stationary jacks in place while working on the car.
Any other options you can think of, and which one would you choose and why?
If you have the space for a 2 post lift look on Craiglists. Alot of car garages are going out of business and trying to sell all the tools cheap. I found a 2 post for $900(I think it cost around $2400 new) just a couple months ago. All I need is some cement poured in my yard and Ill have that sucker installed.
If you dont have the space for a lift,Ive heard about people welding two rims stacked on top of each other and just placing them under all four wheels. This way should give you more room then the ramps. Of course this doesn't look as nice but still gets the job done
I would use four jackstands ...
or two ramps and two jackstands at the rear ...
You will have room and you can lift the 3rd member or other suspended parts, and remove tires ...
Instead of a crawler I like to lay on cardboard and the cardboard sucks up spills ...
I am doing this soon myself ...
I am just as happy out on the driveway with a couple of floor jacks in the warmer weather sliding around in the dirt and gravel, but I have a drive on hoist with a belly lift to get the wheels off the lift when the weather is unsuitable for soaking up the suns rays...I only have a nine foot ceiling but three feet of ground clearance is enough to do a grease, oil and filter...I paid about $1100. and $300. for installation...used of course...this thing came out of a F--d dealership and had extensions on it to do limosines, which I took off because my garage is too short....the new '57 with a connie kit just barely fits in and I have to squeeze my ankles through the space between the bumper and the door to get past...
I had some ramps when I was younger. If you can get over the apprehension of driving almost blind up them, even with a spotter they hold a car well but the drawback was the space they occupied compared to jackstands. Just try working near the transmission with those things in the way....
Been considering one of these, anybody used one or seen one in action?
http://www.kwiklift.com/features-all.htm
Good point on going used instead of new for this option.
Been considering one of these, anybody used one or seen on in action?
Thanks for all your replies.
put the ramps up toward the wall at the front, hang a pillow, and stop before you hear glass break, dryfitting it before using will help with fore and aft placement, also, a mirror on the floor along the left wall would help:
I am considering this because on my low garage ceiling. 4' is better the nothing and you can use a rolling stool. price isn't bad either. http://www.maxjaxusa.com/ You can find them on the internet for 1950.00 with shopping around maybe even less
I have always used these ramps my grandpa made who knows how long ago. He pretty much just stacked a bunch of 2x10s that were a few inches shorter than the last one to make a ramp. I don't know if they are better than steel ramps, but I can say they probably have no limit to how much weight they can hold. I also use a jack and jack stands depending on what I am doing. If I had the money and my own place, there would be a two post lift in the driveway, or garage if it was tall enough.
I always used the ramps to change my oil until 4 years ago when disaster struck. I was driving my 72 up on them next to the curb in the street when the one nearest the curb collapsed. With the road being crowned, the left side ramp had lifted off on the outside putting all the weight on the inside edge, causing it to fail. It wound up jammed beneath the control arm while the opposite ramp kicked out sideways denting the rocker panel moulding. Never again! Now I jack it up with the hydraulic and slip jackstands beneath the frame.
I did allot of research on this and I came up with this portable lift.
I like it because it leaves most of the underside open so you can do tranny work. Plus you can do tire work without using other jacks.
Heres some videos:
http://www.youtube.com/watch?v=E-e0gbT-RF8
http://www.youtube.com/watch?v=6E6dIPaNWUM
This is where I bought it:
http://www.pacetools.com/Products/VMR-6SP
Heres some videos:
Heres some videos:
Heres some videos:
I like mondi1962 system more better. I'd be driving over those "permanent" anchor bolts all the time and getting flats.
I really did see some fat dude weather guy say, It's com'in up a cloud out thar and ya'll are fix'in to get hit directly.
[Translation; You area of the country is soon going to get pounded with rain/storms]
Be safe and stay dry.
My brother is seeking a storage lift for his home garage and is considering this company. http://www.rhilifts.com/products/parking/ You'd have to have high clearance from the ceiling. I'm not sure if this lift is ideal for working on a car, but it offers an option for comparison.
And not easily moved unless you drill more holes.
The scissor lift is not really easy to move but I have done it myself.
You can roll it outside if you need more room to work if you have a concrete driveway.
I have noticed that if the floor its on is not perfectly level it can become slightly unstable and one lower side can lower a little faster.
Also you have to watch not too crush exhausts, fuel lines, gas tanks if its not centered on some cars. It does come with 4 thin and 4 thicker rubber blocks to help make contact with lift points.
It's not perfect but works very well for me.
All things being equal I prefer the two post lift over all others because of the total access to everthing. Changing tires, brake and axle work transmission work, driveline, etc. I do not need it for storage. In a perfect world I would like both a two and four post for different reasons.
I've been using what I call a poor mans lift on and off for years (for significant projects).
Using my large craftsman jack, I jack a wheel (or wheels on rear) and go to the end of the jacks travel, then insert blocks of wood under the tire (or tires on rear). After I re-set the jack and place a block of wood on it, I continue to raise the car until the wheel (wheels) are high enough to slip a car ramp under them. I make sure to oppose the ramps so the stops will never allow the car to roll off. Obviously, you need two sets of ramps to accomplish this. Both my sets are heavy duty, and the ramp section detaches so I only use the under wheel portion. Very effective, provides good access, and I believe very safe. At first, I was a little apprehensive about raising a car so high with a floor jack. It passed after a few times. If the wheels need to be off, I go with four jackstands. I also prefer the cardboard method to my creeper. It is smooth, it insulates me from floor dust and cold, and of course, sucks up any leaks if they should happen.
If I'm only doing an oil change, I drive the car onto a small home-made wood ramp (only about 3+" high) It is just enough to reach under and get the job done quickly.
My dream garage
, will be three bays, a bend pack 4 post in one, a bend pack 2 post in one, and the third bay will have a loft overhead.
My dream garage
I hate that site. It makes me pea green with envy
I am struggling with the lift issue because of my tiny garage. I want one but then I lose a lot of room if I install it. Damn if you do damn if you don't is the old saying.
PS I hate that site as well.
appen.
My dream garage
My dream garage
Quite frankly, the thought of working under a 5000+ lb car scares the hell out of me. But it simply needs to be done at some point in time, unless you plan on using a mechanic for every little thing. So it's belly up to the bar for me, cause I ain't gonna do that.
I liked the small metal ramp idea best until BOOWAH's reply. Yikes...I hope he wasn't under his car when that happened. It make sense to keep your car on very flat surfaces when using any lifting device.
Yeah they really suck on concrete unless you have predrilled holes that you can bolt them in place. I have 4 hydraulic car jacks and 6 jackstands , partly cause I used to have 2 old cars that I was working on but now that my brothers car is sold and out of my hair everything is devoted to the Olds.
There's a 3 ton hydraulic jack for sale at Harbor Freight Tools, with lights that beam upwards from the round flat piece on the extension arm. Cost is only $89. That, along with two jack stands should do it.
But I sure like those lifts examples in the previous replies!
delta_88_germany
May 16, 2013 04:15 AM
