LED Headlights for my 83 H/O
I'm looking to switch over to LED headlights on my Hurst as the stock Halogens are a bit dim in this day and age. Anyone have any recommendations for what I should get? I'm looking for something that would be an easy swap and not require cutting up any wires and would look close to stock. I've seen some that look brighter but don't look very similar to the stock ones. Thanks for any help.
The headlights are sealed beam so you have to get a sealed set. This might work but double check on fitment:
https://www.topgearautosport.com/par...ping%20-%20All
Other option is to get NON sealed beam Hella housings and install LED bulbs. That would probably be the better route:
Hella E-code H1's and H4's and then install LED bulbs inside the housings
https://www.ebay.com/itm/322177900131
84hurst
January 25th, 2010 07:21 PM
