Leak fix in a can
Old Jan 5, 2014 | 02:04 PM
lazy394's Avatar
Leak fix in a can
I see ads for this stuff all over the place, fix your oil leak just add this.
Has anyone tried this stuff?
Does it work?
What does it do to the original oils viscosity and life span?
cheers Scott
Old Jan 5, 2014 | 11:56 PM
rustyroger's Avatar
'87 Delta 88 Royale
Mostly it has chemicals that soften and swell the oil seals, a temporary fix, you will need to address the fault that caused the leak sometime.
Roger.
Old Jan 6, 2014 | 09:48 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Unless its a winter beater run dont walk from anything that says it fixes anything out of a can! Unless its says Bud, Labatt, Petron JD etc...
auto_editor
Jul 9, 2015 07:34 AM
dantecl
Aug 18, 2013 04:18 PM
compedgemarine
Apr 20, 2012 11:47 AM
silverriff
Mar 19, 2010 07:27 AM
GoldOlds
Oct 22, 2007 06:37 AM
