Keyed power source
Old April 10th, 2019, 12:27 PM
roosgunboss's Avatar
Keyed power source
When I had my restoration done I had the company put in after market guages. Unfortunately, they got power from the fuse block on the BAT terminal so they were pulling a constant drain from the battery. Suggestions on a better spot to pull keyed power from?
roosgunboss is offline
Old April 10th, 2019, 01:13 PM
same but different
don71's Avatar
At the fuse box, look for IG that'll give you power with key on. Hope fully, its not all ready in use.
BTW, its really helpful if you tell us exactly what car are you working on.
don71 is offline
Old April 10th, 2019, 05:06 PM
Yes, the IGN terminal is a switched power supply and should be close to the BAT terminal. If something is already plugged into the IGN terminal, just get a dual spade terminal and you can then plug both things into the IGN port.
Fun71 is offline
Old April 10th, 2019, 06:13 PM
If your just looking for a keyed source for a volt meter, then splice into the radio power wire.
oldcutlass is online now
Townie
January 28th, 2020 07:18 AM
rand5204
September 16th, 2019 05:12 AM
Danny Boy
August 22nd, 2016 08:11 AM
ostie13
September 4th, 2014 07:56 PM
Macadoo
August 5th, 2014 06:52 AM
Quick Reply: Keyed power source
